Hey guys
For those of you who remember, I have an Osburn 2300 that smells for the first 1 hr after light up. Nothing has been done by the distributor, installer or company to solve the problem. Therefore, I am getting rid of it. I thinK I may have found a buyer who wants to put it into his garage or cottage.
Here's my situation: the stove is in the basement. I want to be able to heat 75% of the basement and most of the upstairs. My house (per floor) is 1250 sq feet. It's a bungalow. Therefore, I need to be able to heat approximately 2000 sq feet. My chimney is a class A which is outside so the draft is not that great.
I am looking for something that can burn for long times (overnight). I will be using the stove 75% of the time.
I would like something that has a bypass damper or a stove with side loading options (I don't always have the strongest draft and would like to help prevent smoke roll out). I have ample clearance each side of the stove location as well as behind it.
Steel or cast iron, makes no difference. I am looking around the $2500 range (Canadian $$).
Please give me your advice/suggestions!
Thanks again
Andrew
Thanks again
Andrew
