Gooserider
Mod Emeritus
nediver said:BeGreen said:Definitely insulate that liner, it's required and will make a big difference.
I have been told its only required for masonary only chimney and not those already lined with terra cotta. All the stove shops around here say dont bother with the insulation, I would assume if local code dictated otherwise they would let me know.
Yes and no... Remember that Code is only concerned with "safety issues" - it does not really care about performance... From a safety standpoint, the insulation is only required from the standpoint of reducing the potential for damage from a possible chimney fire in a chimney that wasn't otherwise "safe" - a terra cotta tile lined chimney in good condition is presumed to be "safe" in terms of Code, so the insulation is not legally required. The building inspector wants to make sure you don't burn your house down, but he doesn't give a darn about whether or not it keeps you warm.
However the experience we've learned from the many users on the board here and elsewhere, is that external chimneys tend to have performance problems with modern stoves UNLESS they are insulated... An external chimney is a cold chimney, which will tend to draft poorly, especially when starting the stove, and require you to burn more wood in order to keep the chimney warm enough to draft properly. Open fireplaces, and the older "smoke dragon" stoves sent enough heat up the chimney that they could compensate for the poor performance of an exterior chimney, but because modern stoves are more efficient, they are also more sensitive to poor draft.
The local stove shops often seem to be catering more to the interests of the "casual burner" and don't want to scare away a potential sale by pushing the extra cost of insulating a liner, plus it can be a hassle when the customer has a smaller bore chimney than yours, so they try to minimize the need for it. However we have seen multiple cases where adding insulation has resulted in major improvements in the performance of the stove. - Thus we tend to say "required" because we are interested in performance almost as much as we are in safety.
Gooserider
