    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. ColdNH Feeling the Heat
    Bow, NH
    Still trying to figure out the steep learning curve of this thing.
    Those of you with Oslo's, do you shut your air down completely when you’re in cruise control mode?
    I have found 1/4" open seems to work the best for me, seems like every time i close the air more than that, the fire starts to die down.
    With that said my wood is questionable at best. working with 18-22% moisture oak and cherry.
    #1
    Helpful Sponsor Ads!
  2. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    1/4 to all the way closed . . . as you say . . . it's all about the fuel . . . well that and the draft and how hot the firebox is.
  3. mikefrommaine Minister of Fire
    mid coast maine
    On my firelight I kept it at about 1/4.
  4. ColdNH Feeling the Heat
    Bow, NH
    ok 2 votes for 1/4, so im not doing anything crazily wrong here. On my napoleon i was able to shut-r down completly and it would cruise along perfectly. that stove was a cake walk to run in comparason to this oslo.
  5. Michael Golden New Member
    Cambridge, Ohio
    I'm with you on on the poor wood supply, but its burning pretty good. I leave the air open a quarter also as it seems to keep the stove cruising. I can't wait for next year and having drier wood to burn as this is my first year burning!
    Mike
  6. remkel Minister of Fire
    Southwest NH
    You should be able to shut it right down if your wood is properly seasoned. I am running the 600 and shut her down provided the secondaries continue to burn. I am not too concerned if the primary fire burns low.
  7. eyefish2 New Member
    UP Mi
    I have an Oslo and typically cut the air to 1/4 or less (not closed). I have found that I am best off not doing this until I reach 450 degrees F plus on the stove top temp. If I cut the air back prior to this (say 350-400), my front glass will tend to get dirty. I burn oak and do not know what the moisture is.
