outside chimney - duravent or tech or plus ? double - triple wall confused
thedriver
53
Nelson township Ohio
we may soon be moving and need to get a through the wall 6" outside chimney about 20' long. duravent seems to be a good product but, not sure what product would be best for exposed outside chimney. I have seen on this forum that 2 wall insulates better then 3 wall . I am a bit confused. could someone please help with the proper info so I can make the correct choice
Yes double wall insulated class a is a better product than the triple wall stuff
Reactions: Highbeam
DuraTech is the name of the double-wall product. It's good and what we have for a chimney.
It's clear thanks to BeGreen and others that DuraTech (double wall) is better than DuraPlus (triple wall) due to two main reasons:
(1) DuraTech has thicker / more insulation
(2) DuraTech has a smaller footprint (i.e. Takes up less space). DuraTech 8-inch diameter = 10-inch total diameter. DuraPlus 8-inch diameter = 12-inch total diameter.
My question is this - if the ZC installation manual (Heat n Glo Northstar) specifies 'DuraPlus' as a chimney pipe option, can I use 'DuraTech' instead and still be up to specs / code?
Thanks for your help.
Matt
nope you have to use what they want you to use. And DuraPlus is not a bad product duratech is just better,
I called DuraVent and spoke with a gentleman who was very helpful with what to use for my situation and why ( DuraTech ), along with more do's and don'ts, it all sounds correct to me now . I believe it is a very good product that will work well for us . thank guys
So the rep from duravent told you to disregard the instruction from the fireplace? I am curious if heat n glo gave him authorization to do that. I would call heat n glo and check with them. They have final say
Since when does a stove manufacturer have "final say"over what a homeowner does? If it meets the draft requirements and local fire codes, that's it. The manufacturer can recommend all they want. They have no authority over the matter.
Well since manufacturers instructions trump code if you go against their instructions you cant meet code
If heat n glow's engineering and legal department determine or opine that a condition would compromise the safety and safe use of their equipment there's few code inspectors that would sign off on a unsafe condition.
