Hello
Interesting problem. The HR Westpoint I rebuilt overfed once in a while when the original control panel went flukey. It was a weird problem but updating to the newer tried and true DHC replacement panel fixed it for good. This Niagra is a newly designed stove. The manual for this stove shows a new control panel and not a tried and true control panel with all the bugs out.
http://hudsonriverstoves.com/pdf/niagara.pdf
Pellet Stoves need an approx 35/1 Air to Fuel mixture thru all the heat settings. Newer control boards adjust the combustion fan higher with each heat setting to maintain this proper Air/Fuel mixture. Control Panels that do not do this must have a manual damper adjustment to compensate. Normally with a good control panel, the damper needs to be set only once to compensate for the air thickness or elevation above sea level.
Any other comments?
http://maine.craigslist.org/for/3248868144.html
Hudson River Niagara pellet stove..used 2 winters..holds one bag of pellets..the dealer put a new computer in it but it still overfeeds..everything else works fine..i just want to buy a bigger pellet stove
Any other comments?
