Jotul states, for the C450, that the unit is overfiring if any part of it is glowing. I had the top of my unit glowing last night, all too easily (which means over 900F). Here's what happened...
The start up
I did a start up fire with kindling, bark, small pine splits and chunks of silver maple. Within 30 min, the fire was going strong so I dampered down to 50%. The fan was going about 15 min later. No problem so far. I let it burn down to minimal flames, good coal bed.
The reload
I then proceeded to reload with two medium to large pine splits and some smallish chunks of silver maple and elm. As soon as I closed the door, it took off right away. Within a minute, I dampened down to 50%. It was still increasing in intensity so 5 min later I reduced it to almost the absolute minimum (about 1/4 inch from the minimum). I walked away, thinking that I have never overheated the stove with it dampened down to the near minimum. Besides, the firebox was not full, even if there were two splits of pine.
The overfire
I checked things out about 45 min later. The fire was blazing and I could see the the top of the unit was glowing - not bright, rather dull, but glowing nonetheless. I immediately dampened down to the minimum (not much difference there) and put the fan on high rather than low. I could see a spark here and there on the top of the unit (what was that?). Within 15-20 minutes, the unit was not glowing anymore, although the flames were still going very strong (full, intense secondaries for another 30-40 minutes). I measured the hot air coming out of the insert, with the fan set at high, at about 310F...
Why?
So what did I do wrong? The box was not full of wood. I have burned pine before and have never overfired - plus, this was not solely pine, it had other types of wood in there. I had the fire dampened down way before I approached overfire temps... And the fan was working all along. I don't want this happening again but at the same time I don't want to be too shy with the unit - I want some good heat! So what's up?
Damage?
Did I damage the unit? My sense is probably I did not - these things are pretty tough and I have never had it this hot. However, I do not want to make this a recurring event - I would like this unit to last many, many years. Should I modify the primary air control so that I can dampen it down to airtight levels (good or bad idea)? Any other suggestions?
Anyways, thanks for any input.
The start up
The reload
The overfire
Why?
Damage?
