OWB Technical Question
NE WOOD BURNER Posted By NE WOOD BURNER, Jul 3, 2013 at 9:28 AM
Thread Status:
  1. NE WOOD BURNER
    NE WOOD BURNER
    Minister of Fire 2.
    NULL
    Dec 30, 2012
    754
    149
    What is the reason that a non gasser OWB could not benifit from a Catalytic convertor technology?
  2. DAKSY
    DAKSY
    Patriot Guard Rider Moderator 2.
    NULL
    Staff Member
    Dec 2, 2008
    6,650
    1,200
    Loc:
    Averill Park, NY, on Burden Lake II...
    Seems to me that I've heard that OWBs don't achieve the high temps required for Catalytic function...Could be wrong, tho...
  3. NE WOOD BURNER
    NE WOOD BURNER
    Minister of Fire 2.
    NULL
    Dec 30, 2012
    754
    149
    That makes sense. I will need to research the required temp.
    The mass of water im guessing keeps that temp lower than needed.
  4. leon
    leon
    Feeling the Heat 2.
    NULL
    Feb 3, 2013
    381
    15
    Loc:
    Southern Finger Lakes Region of New York
    The ceramic substrate would have to have huge square foot surface area in
    order to create the heat required to burn the smoke and convert it to carbon
    dioxide and water vapor.
    The other issue is idling and it will also clog them up because of that.
    The have to be kept hot at all times to work properly and idling defeats
    that by 100%.
    If outdoor boilers had water scrubbers they would only steam as
    the water would trap all the unburned smoke.
    A firebrick lined fire box and a two or three pass fire tube design with
    the fire tubes immersed in a very long water chamber/reservoir would
    solve the smoke issue as long as the draft is induced and not forced.
Thread Status:
