Hi everyone- I just had a Harman P35i installed..I live in central mass/metro west...I have read the installation manual, a few times..just curious..
I have a few questions .
1. the manual mentions a Draft test procedure - this was not performed. ( I am not using an OAK)
2. Minor cosmetic note: the main door has a small divet in the lower left corner.
5. Is anyone else seeing this:The Control Panel door has the labels on upside down, or it was installed incorrectly, The notch to open the door is on the top and the hinge is on the Let side. The manual shows the opposite, hinge on Right side and notch on top..However, the cut-outs on the door that engage the hinge , do not appear to go any other way, perhaps a manufacturer defect?
6. I am feeling a good draft when I put my hands near the stove, almost as if the flu was open. Should I be feeling this? Is there any reason to omit the sealing plate in the damper?
If I had to do it again, I would have installed it myself..
Thank you for reading,
Netmechdb
Netmechdb
