    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Kherr New Member
    Nampa, Idaho
    This morning, I woke up to a burn pot full of unburned pellets and a shut down stove. (It never lit) I cleaned most of them out and restarted the stove. It fired right up, but I could never get it to burn swiftly, or what I would call normal. It would feed some pellets, then stop, much like it was running in manual and at the room temperature specified. After about 45 minutes, I had to go to work, so I just shut it off. Since it has been almost 3 weeks since I cleaned it out and dusted off the ESP probe, I am going to assume the ESP probe is gunked up. Do you think that is the case, or something else. Thanks in advance.
    #1
    Helpful Sponsor Ads!
  2. Lousyweather Minister of Fire
    America
    dirty igniter? is the rear fines chamber clean? Chunk in the hopper? Pellet bridge in hopper? Gummy feeder syndrome....
  3. DAKSY Super Moderator
    If you're pushing two bags a day thru it, 3 weeks is cleaning time. That's when MY P43 is ready...I'm thinkin the igniter cavity & the holes in the burnpot need TLC...
  4. Sooty_Steve New Member
    Ontario,Canada
    Try cleaning fines out of rear chamber. I had a client with exact problem and that took care of it. Also good cleaning wouldn't hurt.
  5. Kherr New Member
    Nampa, Idaho
    I gave it a cleaning, even though it did not seem too bad. When you folks speak of the rear chamber, are you talking about the area under the igniter of the burn pot, or somewhere else? It was not fun to start, (took forever and dumped a lot of pellets out of the burn pot) but it finally started. Now it is going like hell!
    Each time I have this slow start issue it is when I am burning the same pellet. Coincidence, or not, I am not sure. It would have been 3 weeks tomorrow since the last cleaning, running 1 bag per day.
  6. Sooty_Steve New Member
    Ontario,Canada
    Try this:
    Pellet fines may accumulate in the feeder body over a period of time; therefore, a yearly inspection and cleaning of this area must be performed.
    To clean out fines:
    1. Remove the rear cover panels.
    2. Remove wing nut and feeder cover on the
    side of the feeder.
    3. Use a vacuum cleaner to remove all fines.
    4. Reinstall feed cover, wing nut, and rear cover panels.
    This comes straight out of harman book.
    If chamber has too much dust unit can not supply enough pellets so it shuts down.
  7. Kherr New Member
    Nampa, Idaho
    Thanks. I will clean it out this weekend.
  8. Lousyweather Minister of Fire
    America
    if the feeder fines chamber gets totally full, it will completely stop the stove from feeding, and usually cause the stove to fault out with a 6 blink error. Can also bind the gears in the gearmotor assembly and tear up a gear or two....pretty important to clean this
  9. kinsmanstoves Minister of Fire
    Clean the combustion fan and all of the exhaust. Make sure you clean the ignitor under the burn pot.
    Eric
