    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Highbeam Minister of Fire
    Are you using the IR gun to measure the temp of the stove or of face of the meter?
    #26
    Helpful Sponsor Ads!
  2. PLAYS WITH FIRE Feeling the Heat
    Pittsburgh, Pa.
    Looks like the meter face but it is just below it. It was a major pain to get that close and get the pix! The gun read differently when only .5" away. I even noted the temp of the thermo, moved it then used the gun to get underneath.
    I did it again and what you are seeing is the laser reflection on the thermo.
  3. Sisu Feeling the Heat
    Ontario
    Sorry to hear about the insert. My Pacific faced similar cracks and welding did not solve the problem. I would try to seek replacement at the end of the burn season.
    If it is overfiring, PE should give advice/instructions on how to avoid this. In my experience, there seemed to be a lack of control with the insert. This possibly has to do with meeting the EPA requirements.
    However, if the dealer or PE states that your insert has been overfired, they should investigate the source of the issue. If it is a drafting issue, etc., they should recommend solutions to resolve it. Repairing the welds won't fix the stove, if other issues are causing the insert to overfire.
  4. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    D'oh . . . now you tell me! ;) :)
  5. Lumberjack Member
    Western CT
    I am trying to get quotes to weld the stove. Made some calls today, no quotes yet. I don't want to have to drive the stove all over to have people quote it. When I pulled it, it appears that the primary air inlet is near the front of the stove (approx 3" hole) which can't be fully closed off. Also, there is a 5/8" hole or so near the lower left which is always open. Anyone bend the tab to allow you to close the primary air inlet on stove down more? I would agree that there is some lack of control once things get going though I never really felt out of control. Is there another secondary inlet on the rear bottom portion of the stove? I couldn't really tell.
  6. Sisu Feeling the Heat
    Ontario
    That seems weird that you are the one who has to pull the insert and get the quotes. The insert is not exactly portable; nor is your gas and time included in the repair costs. Did you purchase the stove from a stove dealer?
    I am not sure of the internal workings of the primary or secondary inlets. I do have that 5/8" hole that is under the boost manifold.
  7. begreen Super Moderator
    South Puget Sound, WA
  8. Lumberjack Member
    Western CT
    Sisu, yes I bought through a local dealer. I could push it all on them but in the interest of getting this resolved ASAP, I guess I am driving the ship.
    Begreen, the hole near the front is under a removable steel pan on the bottom front of the stove. With the lever in the "light" position, the hole is partially covered and then remains fully exposed as the air control lever is moved to the right. I will see if I can remember to get a picture tonight for clarification.
    Is the secondary covered up with an "L" shaped piece of steel which moves with the primary air lever?
  9. Lumberjack Member
    Western CT
    Begreen, one other thing, I don't think the Pacific model has the EBT, i think that is only the Summit. Could be wrong.
  10. ozzy73 Member
    ON, Canada
    I am curious, is this specific to inserts ? or is common in any other PE stove ?
  11. Lumberjack Member
    Western CT
    Not sure but I have mostly read about inserts only
  12. Hogwildz Minister of Fire
    Only the Summit and T6 have EBT as far as I know.
  13. begreen Super Moderator
    That's correct. The EBT is only on the 3 cu ft stoves and inserts.
  14. Lumberjack Member
    Western CT
    well, tried contacting PE directly on Friday. Everyone who could help me out was out of the office (of course). So far one welder stated that is isn't worth welding as he believes the material is defective and that welding won't solve the problem. Haven't heard from any others due to the storm I suspect. My dealer is starting to believe that PE should replace the stove.
    In the mean time, I am trying to come us with a contingency plan as it is down in the low 30's here and oil is too expensive. I went to HD today to check out the Englander 30NC. It looks like a good deal but is slightly too large for me to put on the hearth and then pipe up through the fireplace. Can the Englander legs be cut down to lower the stove? My hearth is concrete, brick, stove. Also, what are my options for free standing stove that exit out of the back rather than the top?
    I looked at the Englander insert but it is more $ than I want to spend if I have to replace this stove out of my pocket. The free standing 13 is too small and too tall.
    thanks in advance
  15. begreen Super Moderator
    Use the stove. According to PE the cracks will not affect performance. Might as well stay warm and put that to the test.
  16. Lumberjack Member
    Western CT
    The issue is that it is currently uninstalled. I don't want to put it back in just to pull it again if I actually weld this thing up. Worst worst case I could go pick up the new baffle that PE sent and reinstall the whole thing and run it as you suggested. I would have to wait until next season to install a new one or repair this one.
    Lesson learned here: inspect / clean in June, not October!
  17. RAY_PA Feeling the Heat
    Northeastern PA
    I am in the exact same situation, with my Summit, however, I didnt pull it out, it was all I could do to install it myself, so I dont want to have to pull it unless I absolutly have to. So far, I cant even get a welder to come look at it, after I tell them I have $200 to spend.
  18. Lumberjack Member
    Western CT
    It takes 2 guys to pull the Pacific as well. I can only image with the Summit.
    Just tell them you want them to quote the job and determine if it is feasible. Don't tell them how much you have. PE might provide you with more $ depending on how your quotes come back.
    Check the inside of the door frame with a mirror, I was surprised what I found. That was the worst of the cracks.[/quote]
  19. tcassavaugh Minister of Fire
    Southern Maryland
    have these problems manifested themselves in the free standing ones or have they been pretty much confined to the inserts?
    cass
  20. begreen Super Moderator
    So far we only have reports from a selection of inserts built around '05-'09 I think.
  21. tcassavaugh Minister of Fire
    Southern Maryland
    cool...thank you sir, that means my summit bought a couple of years ago should be ok then. course i hardley burned it last year because it was so warm, i used my little upstairs jotul instead.
    cass
  22. begreen Super Moderator
    We're warm here this fall so I have only done a few fires. It was 64F yesterday, 54 right now. Our T6 still looks as good as the day it was born. That is except for the ashen look inside.
  23. Lumberjack Member
    Western CT
    UPDATE!
    Well, got the good news today that PE is going to replace my firebox! Hopefully it is in on Friday. Guess what I am doing this weekend!
  24. rideau Minister of Fire
    southern ontario
    Great news. Glad for you.
  25. Lumberjack Member
    Western CT
    I will post some pics once it is re installed. I think the new pacific is different than the one I have.
