Paint to cure.
Cure time depends upon the paint that was used and the firing rate you are curing it at.
It doesn't take a lot of time at a high firing rate, at a low firing rate the cure will continue each time you use a higher firing rate.
All I know is it is best done outside if at all possible.
Mine was after one day while not running it all day.
