Pellet dump zone control question
turbulator
119
Western PA
Hello. I have a few posts here describing my Tarm system. Basically it's a 5 zone system, 5th zone being the garage and dump zone combined. It is thermostat controlled but has an aquastat override. It isn't digital it's a dial control.
What I am trying to do is avoid the boiler going into pilot mode and building up a lot of creosote, and trying to keep it somewhat efficient. I can either try to set the override right at the same temp as the dump setting, however that can change based on what I have my water temp set at....Besides it seems pretty hard to do with a dial aquastat - not sure if a digital would really help though.
Would it make sense to install a control relay that is tied into the pilot mode control off the board so that when the boiler goes into pilot, the dump zone kicks on via relay? Seems easy enough as long as I get a relay coil to match the board voltage. I'd have to call Tarm and see if there is enough amperage to run a relay coil however....
Maybe there is even an aux out for this? I guess I'd have to call to be sure...
Wondering how anyone else might have their dump zones set up to be the most efficient?
Thanks
