blazeitup
that stove looks great even without the shell, definatly a ferreri. FYI with outside air that stove is approved for 12" from window, not to mention how do u hav that 4' horizontal suspended anyway jus curious?
Pelleting In NJ said:I have a support strut to brace the pipe to the outside wall. I know that with OAK only 1 foot clearnace is needed, but I want to minimize any sooting of the light colored siding of my house.
myers7457 said:let me know how often you clean your burnpot. I have been cleaning every other day. There isnt much soot but the holes in the burnpot get covered. The window stays clean as well as the exhaust cleanout. I am burning lingetiics. I was thinking about getting several bags of something else. very happy with stove so far wating for some real cold.
Pelleting In NJ said:Since I ended-up with a horizontal flue config, I am considering to buy a UPS back-up unit to power the stove for a few minutes so that there is no smoke back-up if the power fails. I found a pure sinewave UPS, Cyberpower CP850PFCLCD, about $120, that will supply 255 Watts for 8 minutes. I would guess the combustion blower and convection blower use about 120 watts total, so I should be able to get about 16 minutes of run-time for the stove to shut down properly. To get the stove to go into shut-down mode automatically, I will put a set of N.O. relay contacts in series with the auger motor, so the contacts open if the 110VAC power drops-out. The stove will then run out of fuel, which will make the stove go into shut-down mode. Any thoughts? Any favorite UPS systems that people use for their stoves?
Second Burn Season Update : Fired-up for the first time yesterday, still going strong. Bought 2 tons of CC Smith pellets. The only negative is that the "Firex" liner of the firebox is very fragile, trying to clean some "baked-on" ash resulted in a small piece of the Firex crumbling off. You have to be careful to only touch the Firex with a soft brush when cleaning.
Last year I burnt 2 tons of Great American pellets.
I also hooked-up my home-brew automatic auger disable, which cuts off if the power fails, so that the flame extinguishes and my UPS can run the combustion blower long enough to clear out the smoke. The auger disable has a push button to manually reset it when the power is back.
You can use just about an non combustible pad because the Ecotecks have an inch air space under the stove, You can use glass if you want. Looks very modern.My Ecoteck was delivered yesterday, ordered my flue pipes today (Dynamitebuys).......now just need to decide what to do for the floor protection......I think my township inspector wants to see at least an inch thick pad....even though Ecoteck just specifies a non-combustible floor protector that is at least 0.02 inches thick ! I don't think I need any, since the floor is ceramic tile over backerboard.....but I understand that the Inspector has the final say.
How bad did you get hooked for the spare igniter?View attachment 117773
