    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. jimmieguns Member
    Long Island, NY
    North American Pellets tonight b/c thats all Lowes had left--not my 1st choice--like the hardwood Green Supremes BUT he house is way WAY hotter tonight with these North Americans which everyone seems are poor quality--- 1st time using here so too osoon 4 me to comment........like the heat--may be b/c of all the snow on roof insulating the house better....
    thoughts??? on these appreciated
    have an Englander 55trp-10 (timberridge,summersheat)
    **also posted in a diff section on storm 2013 ***
    #1
    Helpful Sponsor Ads!
  2. thedude110 Feeling the Heat
    Central Connecticut
    I think most will tell you the Green Supremes are junk. North Americans may well be warmer.
  3. john193 Feeling the Heat
    Southeast PA
  4. DexterDay Minister of Fire
    NE Ohio
    North Americans are an average pellet. But Green Supremes are below average. IMO...
    I measure all my output temps with a K-type thermocouple and the GS's are some of the lowest temps I have read. Other than Penningtons. My only complaint with North Americans is the chemical smell?? :(
  5. jimmieguns Member
    Long Island, NY
    yeah thanks Dex for reply-- cleaned the stove today-the daily quickie- and had MUCH more ash than from Green Supremes-- so THAT i dont like but the heat levels coming from the Northerns is HUGE diff--- i thought i should only burn "hardwood" pellets- but am i incorrect on that? seems the blend is hotter-- the atoves EATS them up tho---almost double the usage against the gree supreemes-- guess i gotta weigh the diff in heat output from cot and decide?
  6. DexterDay Minister of Fire
    NE Ohio
    Hardwoods and Softwoods are not equal..
    Just like in a Woodstove, Softwoods are Hotter and Burn Faster.
    Its like the old Wives tale of burning Pine ;) Gonna start a Chimney fire!! Really? Tell that to the people in the PNW or Canada (all they have is Pine and Fir).
    Most Softwoods are Hotter and Burn MUCH cleaner. :)
    I love Softwoods and I love Pine for my Wood eater. ;)
  7. jtakeman Minister of Fire
    Northwestern CT.
    Northerns? I think you mean North Americans. Northerns are a totally different breed. Much better quality IMHO.
    Both the North Americans and the Green Supremes are blends they both contain a mix of hard and softwood.
    All I'll say about softwoods is "once you try some you will be hooked"! I though the debate was all over. Does your manual stat hardwood only? I know some of the older units did have warnings in the manual. Trust me, The myth has been debunked. Softwoods from a quality mill will roast you cans and you'll be amazed at how clean the stove will be. Try some if you dare! ;)
    I burned pine in my wood eater too. Should seen the looks I would get from all these New England hardwood peeps! "Your gonna burn your house down" was the usual reply! Maybe if I burned it wet? An extra bit of seasoning and a moisture check gave me the quickest spring/fall warm ups I could ask for!
  8. DexterDay Minister of Fire
    NE Ohio
    Yep.... Same here. Love me some pine. Just season properly (as Any wood should)
    Burning pine will start as many chimney fires as it will make Millionaires ;) lol
  9. Thaddius Wenderoth Feeling the Heat
    While on the topic of pellets....
    I just bought a stove and the gal told me she would give me the rest of the pellets she had as well. I was like great free pellets! I should have left them. They are future fuel and these things are amazing how bad they are. I would say literally 5-10% fines. Lots of pieces of wood in there not in pellet form. I have been burning Lignetics and I think I have been spoiled. There is virtually ZERO fines. I see none at all even when I poor the last of the bag in. And there are only pellets in the bag, no 2x4's.
  10. jimmieguns Member
    Long Island, NY
    Thanks Dex----- love the heat coming outta the Northern Americans....the gree supremes say they are prem hardwood- so i guess abs NO softwood in there--the GS run so much lower on heat scale
  11. jimmieguns Member
    Long Island, NY
    Oh- and another thing I noticed since using diff pellets than Green supremes-- i WAS getting a nasty squeal out of the stove---and its 3 weeks old!-- since using the North americans-- noise is gone.....hmm.... maybe a problem on the way at later date with a fan-i dont nkow- maybe but for now i am betting its the pellets...........
  12. DexterDay Minister of Fire
    NE Ohio
    That squeal is the Carbon build up on the Lower auger. As it spins, its hitting the walls and "Squealing". A different pellet can help (less carbon) and them burning hotter will help also (burn the Carbon).
    The 2 auger stoves are notorious for this. Scraping the carbon when you do your weekly cleaning (or bi-weekly?) Will help eliminate this. A small screwdriver or chisel and a small hammer.
  13. john193 Feeling the Heat
    Southeast PA
    Since we are on the topic of softwood or hardwood, can you guys think of some softwood pellet brands? Can't find anything in PA for the one I know (I.e. vermonts). Alternatively, might pickup a bag of horse bedding from agway for a change. :)
  14. Hoot23 Minister of Fire
    Alfred, Me
    Just started the Vermont's a few days ago. No fines and hardly any ash. Best softwood I've run in my stove.
    Softwoods- Vermont, Spruce Pointe, Mcfeeters, Trebio, Maine Woods, La Crete, and Okies. Don't know if you can get any of those in PA.
  15. john193 Feeling the Heat
    Southeast PA
    Thanks - googling now
  16. SwineFlue Member
    NE Pa
    I haven't seen any of those brands. The only softwoods I tried were some Rocky Mountain pine-beetle-kill at TSC few years ago.
  17. john193 Feeling the Heat
    Southeast PA
    Yea, nothing in my area either. Full of hardwoods here.
    I noticed you had energex listed in your signature. How do you like them compared to the barefoot? I've tried barefoot, but not energex.
  18. will711 Minister of Fire
    Pocono mts.
    No soft woods in PA that I know of . Did find a place in NJ that was selling Okies last year ,but price was high .
    Edit:imperial billiards .com pool table place
  19. SwineFlue Member
    NE Pa
    I just cracked open the ton of Energex the other day. Burned a couple of bags, but switched back to the Barefoots for the single-digits last night. The Energex seemed pretty good... less ash than I expected. I'll switch back to them today after the hopper's empty.
  20. john193 Feeling the Heat
    Southeast PA
    hah, nice find. Too far for me to drive around considering I can get barefoot, country boys and hamers within 12 miles.
    will711 likes this.
  21. jtakeman Minister of Fire
    Northwestern CT.
    Mr Warm offered a comment on why no softwoods in PA. Just though I would share, Don't shoot the messenger!
  22. will711 Minister of Fire
    Pocono mts.
    I hear ya, about an 80+ mile round trip for me and I would only be able to haul a 1/2 ton don't know if they sell single bags. Would I like to try them you bet , but I can get Turman's and Hamer's on my way home from work :cool:
  23. will711 Minister of Fire
    Pocono mts.
    Thanks Jay :) It's just simple economics . If they can't make a profit your going out of business.
  24. jtakeman Minister of Fire
    Northwestern CT.
    Nothin shabby with those 2 brands. I bet you pay much less than I can get em for. Consider yourself spoiled IMHO! Turmans rock and Hamers are Hot to trot! ::-)
    There is a few southern softwoods that pass through PA on there way to New England. Have your dealer do some digging if you are interested.
    • Potomac
    • EasyBlaze
    Both are from Southeastern Virginia. Might not be as top notch as the BC softies. But they will hang right with the likes of Energex and GAP/PowerHouse. Definetly cleaner than the average hardwood with comparable heat. Price would be the balance point.
    Edit:
    American Wood Fibers also has a softwood out this year. They have a plant in Ohio.
    One other thing is to look at the local feed stores that carry horse supplies. You can get pine bedding pellets. Might have a few more fines in them, But will give you an Idea on how a softwood pellet will burn in your stove.
    will711 likes this.
  25. SwineFlue Member
    NE Pa
    Can't really argue with that! Thanks. So who is this mysterious Mr Warm?
