Pellet stove cleaning
rick31797
133
Canada
I would like too know how many hrs of running your stove before you vacuum it , also how many hrs of running too clean the chimney.
I have a Thelin parlour 3000 and i can get about 16 hrs before it will shut down..and i need to clean it.. I Noticed that the last couple times i am getting less time, probably not cleaning it as good as i should. The last time it only run 4 hrs before the red light came on and it shut down.. may have to clean the chimney.
I am only running this stove part time, about 5 days total a month. One feature it has when cleaning is, you turn the fan on a clean cycle and it will stir up ash and u use the vacuum, as the fan is running.
Does anybody take the clean out off the bottom as far as regular cleaning..I am wondering if i should hit the pipe and that will allow some ash too fall..
This feature i cannot use as the fan is slightly bent and will hit the side casing.I plan on replacing it with a new one when the season is over, other then that the fan works fine.
These stove i dont think are as easy too clean, as there is no ash pan.. Just wondering your thoughts, and maybe somebody has the same stove and can give me some ideas..in proper cleaning.
I also use a ash Vacuum and i have a small hose too attach too it too try and get in around the heat exchanger., and in small areas
I give my pellet furnace a quick vacuuming with my Shop Vac after each run (I don't run my unit 24/7, just during the day on weekends and evenings on weekdays, I shut it down at night), just to pick up the residual ash which keeps the airflow unrestricted inside the burn chamber. As for the PL vent, I plan on cleaning that out using a brush and leaf blower at the end of the season, unless I notice any significant build-up before that point. So far, the PL vent seems to be fairly clean after burning about 15 bags or so since the unit was installed about a month ago at the end of December 2010.
Best advice is to follow the suggestions in your pellet burner manual, depending on how your vent was installed (if you have a lot of horizontal piping), it may need to be cleaned a couple of times during the burn season, my Fahrenheit manual says once per season if you are burning premium grade wood pellets. Corn and other biomass fuels require more frequent cleaning. Since you're only running your pellet burner 5 days per month, a once-per-season PL vent cleaning is probably more than enough. I know several people who run their pellet stoves nearly 24x7 and rarely clean the vent unless they notice problems, so some only clean it every few years, others clean their vents multiple times per burn season. The size of the pipe plays a role as well, 4" vent pipes (what I use) aren't as prone to ash build-up problems as 3" pipes.
One thing i forgot too mention is, i burn this stove on low setting most of the time except at start up.. On low setting do u get more ash build up.. and therefor would need to clean more often?
On a low setting the flame is usually a little lazier and you might have slightly more ash than if you burned on a higher level, but it shouldn't make too much of a difference. If you keep the inside of your stove clean and your flame seems to burn sharply (bright orange/yellow with some slight blue at the bottom of the flame), your stove is getting good airflow and your vent is doing its job. A dirty or clogged PL vent will affect your flame - it'll make it look lazy/dark orange and you may get some exhaust or smoke in the house, which can be dangerous (CO issues), so there are usually warning signs if your PL vent is clogged.
Breckwell P-24 at the house has been vacuumed once this season (has been running since October)
Heatilator at the store, three times this season
All the other stove (4-5) usually run for a few weeks to a month and someone will buy them.
You have a pretty stove, but if it won't run longer than 4-16 "before shutting down" then you a good conversation piece. You need to get in there and Clean It.. Get all passageways for exhaust, behind all baffles, PL vent, scrape your pot, clean holes out, etc. Do you have an OAK?? What brand of pellets are you burning? The cleaning should take you a few hrs if your not used to the "routine". But your Pellet stove should burn for Days if not Months. And Yes you will get more ash on Low than High.(Low airflow thru the pot). I use mine as my only heat source, 24/7. (Except for cleaning). I wouldn't have a stove that would only run so long.
I dont know what an OAK is.. I am using CUBEX pellets, I Never spend more then 15 mins cleaning it.. i clean the burn pot and vacuum around inside, and take off the metal shield that covers the heat exchanger, and try and get the vacuum hose inside , dont really know anything else too clean.. other then take off the bottom of the clean off T , on the stove pipe and clean there..
Cleaning for a few hrs must involve taking the stove apart.We have a gas furnace so the stove just helps on very cold days.
An OAK is an outside air combustion kit, that means you have a vent that draws in outdoor air that your stove uses for combustion, this improves the efficiency of the pellet burner. Cleaning out the vent pipe will surely help if it's clogged with ash and soot. If you've been cutting corners on cleaning, open up your pellet stove manual and read through the cleaning guide. As Dexter mentioned, take the baffles out, clean around the heat exchanger tubes, brush the burn pot holes with a stiff bristle brush so that they are clear and open, and clean out your intake and exhaust air vents so that they are free of soot/ash.
I have the Thelin Parlour 3000 also..... I run 24 hours a day and 7 days a week..... I clean mine every Sunday before football starts..... I'm good for the whole week easily..... You need to pop out your burn pot then pot out the gizmo that the burn pot sits in.... It has the ignitor running through it..... It just pulls strait up and the ignitor slides out sideways..... If you do not do this you will have ash build up in areas you cannot see.... I do the "leaf blower trick" about every ton to ton and a half..... Mine is heating the whole 2000+ sq ft with 10 foot ceilings house to 75 on the 1st floor to 62 on the second floor on the medium setting..... I am burning Hamers Hot Ones and Barefoot pellets..... I suspect you need to clean your stove real good and the leaf blower thing wouldn't hurt either.....
I clean my Thelin every sunday also and I am running it all week as primary heat source. I would definitely open the clean out tee and empty whats there. The red light that you have coming on isto show a blockage in the vent or a high wind condition backing into your exhaust, so if you are getting it regularly that pipe needs to emptied. The leafblower trick works great for me 2 or 3 times a season to keep it clean. Also, I agreee completely with Baddad320, removing the bottom of the burnpot and vacuuming there regularly makes a big difference in how it burns.
I was told by JAY when i installed the stove i didnt need an outside air inlet, i think he said it would decrease the efficiency of the stove bringing in the cold outside air.. the room is very large, the stove is in 10 ft ceiling.. so i thought there may be enough inside air.
I Dont know the leaf blower trick in cleaning the stove, maybe u can explain, but you did hit on something.. ok the burn pot, i have had that out and made sure the holes are clear, but thats as far as i went.. u mean there is something the burn pot sits on that comes out.. that may be the problem.
i also cannot use the clean cycle, fan is bent and hitting on the inside.. i have a new fan for it.. the new tech guy at thelin told me the clean cycle is a help but u can clean without using it..
my stove is a 2002 model, no igniter, i have too start manually.. i have never got more then 20 hrs before it shut down, so i am not cleaning it proper , i know that for sure. atleast i know the senors are working.
Outside air combustion (OAK) is a must if your house is tight (i.e. a house built in the past 10-12 years), but it's not always necessary and/or a good idea. My Fahrenheit pellet furnace required an OAK, it was a mandatory part of the installation. For some other pellet stoves, OAK is also mandatory. Hearth.com actually has a nice article explaining OAK in more detail...
https://www.hearth.com/econtent/index.php/wiki/Outside_Air_Kit_-_Why/
This house was built in 1975, 2x4 outside walls, not 2x6.. its not airtight, but with all new windows and doors, its pretty good, for what how old it is...
I am running my stove 24/7, and every day I scrape my burn put and heat exchanger tubes twice a day and use a paint brush to sweep the ash into the ash pan. Once a week I will shut her down and do a real good cleaning, VAC the inside, ash traps etc. every ton I will do the leaf blower trick, and also once a month I will sweep the vent pipe out.
The metal gizmo that the burn pot sits in pops strait up.... Wiggle it a little and it should come loose..... As you pull it up you need to slide the ignitor rod out...... See all the ash you missed down there ??????? The whole ash retention area should now be exposed.... Nowhere for ash to hide !!!!!!! The leaf blower trick is explained in here in a few places..... Just do a search..... You can also youtube search "pellet stove cleaning with a leaf blower" for some video...... The leaf blower trick is basically using a suction leaf blower on the end of your pellet pipe outside sucking out all the crud in the exhaust pipe..... Quite the sight........
Mine dont have an igniter.. i have too put some pellets in the burn pot, then put some gel starter on them and lite them, and turn the fan on.. i have never had the gizmo, out.. so maybe this is a problem..
I am a bit confused, about what comes out... i will try and post a picture.. with the burn pot out.. u mean the large metal thing or the small metal thing in the bottom.. i dont want to start banging on something that is not meant too come out..
Yours is different than mine....My stove is 3 years old.....Wow.... oops..... Sorry....... A picture is worth 1000 words......
I dont think mine comes out it looks pretty firm, when they started putting in igniters they probably had to change the design.
The newer Parlours 3000 have a different firepot setup...I just bought one and called Thelin...my issue was that I had a new stove with an older manual...so the manual did not match my stove's setup...the firepot design has changed...seems like it easier to clean...
