We are from south georgia. We are in the process of building a house. We were thinking about buying a prefabricated wood insert for the house. While at the retail store, we came across a pellet stove. the one we looked at had a thermostat on it self loaded the pellets. Sounds like a great concept - no cutting wood, no having to get up in the middle of the night to keep fire going, etc. So we started doing research. The brand we were looking at was a Quadrafire. Then we moved on to Harman. We have just about concluded from everything we are reading that any pellet stove requires alot more attention than we originally thought. Seems like whatever brand you get, they all have issues. So now we are almost back at the idea of sticking with the prefabricated wood insert. We would appreciate any and all suggestions, positive and negative, about pellet stoves.
The other thing is that folks are telling us if you get a prefabricated wood insert that you don't really get any heat off of it. We will have a heat pump so are not going to be using insert as a main source of heat, more as a supplemental heat and of course the ambience! Thanks for all your help.
