I'm sure some guys have some "less than legal" installations in a shed.
Care to share some pictures?
I'm looking to put in a small jotul or the likes in my shed (whatever I can find on craigs for as cheap as possible).
It's an old shed, it's built on bricks that are stamped from 1927. 75% of it is rotted away, and it looks to be made with tin siding, or something. I really have no idea.
But anyway, I have to get work done that can't be done in the house.
So I want to heat it.
The shed is worth about $ -5000 to me, because it's so terribly ugly and I would be thankful if it burned down.
But I'm not one to tear down something functional unless it has to be.
So what do you guys use?
Do you still stick with the traditional requirements? Still Class A/Triple wall chimney 3' above?
What about hearth?
Mines going on a dirt floor, so I was thinking of just putting it on blocks and calling it good.
There's a spot where a small window was cut out of it, maybe 2' W x 1' H
Figured I could just grab some steel from work, pop a hole in it and use that as the chimney instead of a thru the wall kit
What about hearth?
