Todd said:BrowningBAR said:Todd said:BrowningBAR said:Todd said:Waulie" date="1315008611 said:Are you guys going with the ash pan?
I haven't decided yet. I'm waiting to see an actual stove put together first. The ash pan looks so huge and prominent on the images. They told me one could be added later very easily, so if I don't like the way it looks I might just go with ash shoveling for at least a while until (and if) I get tired of it.
I've been wondering about the ash pan option. I wonder if you go without if they replace the slotted cast iron bottom grate with fire brick or soapstone and also if it changes the size of the fire box? I know on my Keystone I could remove that slotted grate and place 3 fire bricks on the bottom and change the fire box size from 1.4 to 1.8cu ft. If they are similar the new stove could jump up from 2.75 to about 3cu ft fire box? Anyways I like the ash pan so much more than shoveling out the old Fireview the Keystone is staying the way it is.
That's interesting. I did not know that.
Yeah, I took it out and 3 standard sized fire bricks layed right in there and gave me about 2" talller fire box. That gives you about the same size box as the Fireview but the Keystones cat is a tad smaller so I don't know if that would make a difference or not. Maybe I'll do a test this year and see what happens.
Which means the Keystone probably puts out as much heat as the Heritage.
Could be, you might want to measure that heritage fire box of yours, I think you will find it much smaller than advertised.
Well, considering I have the Encore sitting next to it, which has the same claimed fire box size I don't think I need to measure to know that 2.3 means different things to different manufacturers.
It's a good stove, but my needs are a little uncommon.
