jim c said:Ha Frank
thanks for the advice. What sthil model do you think i should buy.
Jim
Saw-dust said:Dolmar is a good saw. I have sthil but have seen the Dolmars run. I have no idea how they hold up but they do cut perty strong.
I had a Poulan that did that. It had a cracked crank case behind the flywheel. When cooled off the crack would seal up enough to let you start up. After it got runing it would shake the crack enough to suck air and lean it out.
I dont know dolmar sizes but I would not get anything smaller than a sthil 290 if i was limited to just one saw. The 440 is too big for general use but great on bigger stuff witha 24 inch bar. Something like a sthil 361 is just right for a one saw show. Best if you had two bars, one 16 and a 20.
If you got pinched up you could take the motor loose from the stuck bar and get your self out with the other.
