Pre-Fab Fireplace Advice Needed
Longhshanks
2
Pocono Lake, PA
The house we recently purchased in the Poconos has a Lennox LBR-4324 pre-fab fireplace in the main room (open plan kitchen, dining area and living area with a cathedral ceiling). It is visually attractive but doesn't seem to generate any real heat in the room from a wood fire. Given how low the temperature gets in winter, we would love to get some useable heat from the fireplace on cold evenings and weekend days, so I am looking for some recommendations on what to do about this. Should we be looking for a replacement pre-fab with better heat output, or should we be going in a completely different direction? We love wood heat, and so would like to stick with that if there is a solution that makes the heat output worthwhile.
From the manual it looks like an insert is not permitted in this fireplace. That leaves a few options:
a) replace with a modern, high efficiency EPA fireplace or
b) tear it out and put a freestanding stove in its place or
c) install a wood stove for heating in another location in the house.
Thanks for the quick reply. Can a high-efficiency zero-clearance unit get close to the heat output of a stove? I like the idea of sticking with the current "insert" look of the Lennox if there is an option that can generate good heat.
Yes, some can and they have the option of ducting some of the heat to another part of the house.
