Preventing Possible Freeze up
dean
4
brookhaven, ny
The Jotul wood stove has been keeping our reliance on heating fuel down this winter. Our house is a Split ranch 1950's built, garage under bedroom area, mono flow hydronic baseboard system. I kept a thermometer in the garage to monitor temps at night. They stayed above freezing 35 - 39 most nights. Concerned with a possible freeze up, I recently purchased the Therm Guard. It was easy to install and program with just a slight modification to the back of the mercury filled thermostat.
Just trying to figure out what you mean by Split Ranch?
http://splitlevel.net/
Regardless, my Split level enters into the living room and kitchen with basement/family room down from there and bedrooms up over the basement/family room. The garage is under the living room and down from the basement/family room. My garage is mostly underground on the sides and of course open to the elements on the door side. My garage never gets below freezing. I wouldnt even give it a second thought if you have checked the temps. The garage floor being concrete and mostly influenced by ground temps should allow you to rest easy. I can leave a pot of water on the concrete floor by the garage door and it will never freeze.
Your only issue is if you have some exposed pipe in the floor near a wall where you may have a draft...
It is sort of a California style. There was an extension added to the original footprint of the house and has a wood stove. The bedroom side of the house has full basement with garage below. This side of the house has north, northeast exposure.
