    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Dee New Member
    I have just installed my quad-7100 in my new house, but I have one problem... the fan just turns off and on randomly while burning a good hot fire, it will never stay on for more than a few minutes. The only way I can avoid listening to it turn off and on all the time is by turning the override 'on' and turn the fan to a really low setting, otherwise the dang thing will just turn on full speed every few minutes and turn back off... even if I have the override 'on' with the adjustable nob clicked off. What do you think? Everything is brand new!
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    Make sure your thermo disc is in contact with the stove body. If there's a gap between the disc & the hot surface that actuates it, any air passing thru that gap will cool the switch to the point that it opens & the power to the blower is cut off. Once the air flow stops, the t-disc will heat up & close again to power the blower.
  3. raybonz Minister of Fire
    Carver, MA.
    Are you saying your blower is cycling on and off with it in the always on mode? If this is the case your motor may be cycling via the internal motor thermal protection meaning your motor could be overheating.. I would need a wiring diagram to better understand this..
    Ray
