Propane now.......basement boiler to forced air furnace
DPQ Posted By DPQ, Jul 26, 2013 at 11:04 AM
Thread Status:
  1. DPQ
    DPQ
    New Member 2.
    NULL
    Jul 26, 2013
    3
    0
    Loc:
    Michigan
    I live in Michigan in an old farmhouse with somewhat poor insulation. It is about 3500 square feet. I am not interested in an outdoor boiler. I cannot get wood for free. I am looking hard at the PB 105 pellet boiler to use for hydronic coils added to the plenum in my main furnace and in a smaller attic unit. I would like to use for DHW as well. Does this seem feasible and likely my best option. Pros and cons would be appreciated. If there is a better boiler out there I would be interested in researching that as well. Thanks.
  2. hobbyheater
    hobbyheater
    Minister of Fire 2.
    NULL
    Nov 14, 2011
    1,069
    423
    You have duct work in place , why not go with just a pellet furnace ?
  3. bmblank
    bmblank
    Minister of Fire 2.
    NULL
    Jan 17, 2013
    698
    257
    Loc:
    Michigan
    Need hydronic if you want dhw.
  4. hobbyheater
    hobbyheater
    Minister of Fire 2.
    NULL
    Nov 14, 2011
    1,069
    423
    The pay back time for a Boiler for just DHW would be large. Depending on the amount of hot water used, demand electric, propane or gas for DHW is a option.
  5. DPQ
    DPQ
    New Member 2.
    NULL
    Jul 26, 2013
    3
    0
    Loc:
    Michigan
    The ductwork in the house is a split system. Going with a pellet furnace would require a pretty major rework of existing duct that would have to include a tie-in of the upstairs attic based system and the lower floor/basement system. By staying hydronic I can feed both coils without changing the ductwork. I just want to make certain that there is enough BTUs in the system I purchase.
  6. hobbyheater
    hobbyheater
    Minister of Fire 2.
    NULL
    Nov 14, 2011
    1,069
    423
    The boiler then makes sense!
    I have no experience with pellet boilers but there are some very experienced people on here and hopefully they will chime in, although this time of the year is the slow time for help.
    Best of luck.
  7. stee6043
    stee6043
    Minister of Fire 2.
    NULL
    Aug 22, 2008
    2,548
    241
    Loc:
    West Michigan
    Are you hooked up to natural gas or propane? If you're NG I think you may be wise to research NG boilers instead of wood. Even if you're on propane a high efficiency unit may make more sense. Perhaps with a small investment in insulation as well. Paying for wood has always seemed like a losing proposition to me. It's a lot more work than many will realize. If you have to pay for the wood on top of the amount of work it is to manage the piles....I just don't see the payback. My two cents only, however.
  8. DPQ
    DPQ
    New Member 2.
    NULL
    Jul 26, 2013
    3
    0
    Loc:
    Michigan
    I am on Propane. I just received a card today from my propane suppliers quoting a price of $1.69/gallon for first fillup and $1.77 locked in for the next year. I average close to 300 gallons per month. So it is just under $4000 per year. I think I can cut that in half by going with a pellet boiler don't you think?
  9. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    Crunching the numbers you come up with this:
    Propane at $1.77/gallon and typical efficiency of 80% for an iron boiler yields a cost of $24.22 per million btu's
    Pellets at $189/ton and efficiency of 85% from a Windhager yields a cost of $13.48 per million btu's
    So you're looking at roughly a 45% reduction in outlay for fuel.
    (I don't know what pellets are going for in your area so I used the cost of what we can buy them for here locally)
  10. stee6043
    stee6043
    Minister of Fire 2.
    NULL
    Aug 22, 2008
    2,548
    241
    Loc:
    West Michigan
    Using Heaterman's math above let's say you save $2,000 per year switching to pellets. Let's say you invest $6,000 in the pellet boiler system. That's a three year payback on the boiler.
    Using really, really rough numbers it looks like you're going to be somewhere in the ballpark of 40-50k btu/hr heat loss at your house. That's pretty high for an average. I'd bet investing $2k-3k in insulation and perhaps some new windows would reduce your heat loss quite significantly. Maybe even by 50%? I don't really know how feasible this is in an older home but insulation is money very well spent in most cases.
    Again, I'm only sharing this angle because you have to pay for wood/pellets. Most of us around this forum aren't paying for the fuel so our justifications for our systems are radically different.
Thread Status:
