Public safety announcement - masonry fireplaces igniting wood headers, etc.
just talked to elk and he walked me through it i am ok!!!
thanks alot guys!!
now off to bed wifey is huffing ... time to make babies!!!!
Craig the time to fix the problem I discussed is prior to the insert installation. Don't ignore it it plain does not go away If that wood has been payrolized all it takes is being exposed to 300 degrees do not even need an open fire. One wiyth the rest of the story
I was filed in with some additional details of the fire I inspected it seems the fire place was operated Saturday the call to the fire dept was 2:00 pm Sunday that fire smoldered in the wall an entire day before it broke out meaning all night as they sleep. once it broke out and found a source of oxygen the entire gable end of the home is gone only remaining some charred studs
and the chimney it was gone by the time the fire dept got there to begin fighting the fire.
Required is a full level II inspection prior to an installation of an insert that not a scare tactic but code.
as for un tested fire places no there is No UL listing but ASTME test the cements blocks and brick manufacturing. And code cover the require thickness of stone and rubble built fireplaces.
I check all the construction during a throat inspection and again during the final inspection so IT is required to be inspected to be code compliant no fireplace gets passed with the formentioned void to the header. during my inspections.
I looked at his fire place construction in the pictures Iceman is better off and safer with an insert and a full liner that throat area should not be coupled bricks but parged smooth tapered walls built to support the fire flue. Perfect example of not a correctly built throat. This is common of chimneys built in the 60's also making a good case for using a full liner.
Craig this safety message is real and not to be glossed over. It is best to recognize the deficiencies and correct them. It can be accomplished with refractory cement and a caulking gun.
to these people living in motel rooms or a trailer during the holidays is not a vacation . For less that $10 in materials they would still be living in their home If they only knew.
The photos show bare brick. I may be missing something here but it appears that the fireplace should not be used at all.
Did I miss something?
Jim you are seeing exactly what I am, incorrect construction of the throat. Like I said ticking time bombs. Looks like his fireplace was never used no signs of any ash or creosote build up.
with a liner passing threw the throat area to the insert he is a hell of a lot safer using an insert than as an open fireplace
I don't care if I scared the crap out of a few posters. If some learn and correct the fire box deficiencies, then the message is well worth it.
It could save a few lives. I really feel for that family. I wish I had looked at that fireplace prior to them lighting up. All I can do now is to alert others to look at their situations
does anyone know the number of related chimney fires in USA a year? that include appliances connected to the chimneys 140,000 also lighting strikes.
So web is this a big enough concern ,or if you wish , I will not make these public service post? Here is another one 15,000 clothes dryer fires a year 23 deaths
when is the last time you cleaned you dryer and dryer vent?
what about over loader lamp wire extension cords or power strips?
so there should not be any brick showing? before the flue?
my fireplace in the base looks the same way but with a bigger flue that has been burned and was just inspected and cleaned 3 weeks ago
i was told it was fine and whatever i burn keep doing it because there was hardly anything in it
Ice By today's standards the bricks above the damper called the throat area should be smooth sides tapered to receive the first flue liner most masons go a step further and smooth on a layer cement to create smooth sides a process called parging If you check yours frequently and note build up that is the issue. If no creosote build up then it ok.
the issue is also to channel the exhaust to a smooth transition into the first flue Not that much of a safety issue without cresote buildup storing it on the ledges of the bricks jutting out
that the biggest concern
Elk, great post. Just reading through, I realized a lot of concerns with my own flue! We had burned our open fireplace for a solid year before we installed our insert.
Fortunately for us, our flue was a tapered design, without any offset brick ledges to hold creosote. I have a very knowledgeable neighbor who help prepare the flue for our full liner, by cutting out the damper plate and scrubbing and cleaning the tapered brick up to the start of the tiles, just to check for any past damage. He found out the hard way years ago, by burning an insert with a direct connect....one chimney fire and a climb up a snow covered roof in the dark scared him senseless. Now he doesn't recommend anything but a full liner and monthly sweeps and inspections.
I think it's good to scare a few people into looking into their own installations. I read this thread long and hard for details that applied to my situation. It looks like everything was done okay in my case, which is a relief.
ok thanks agin elk i was starting to get sad thinking i could have ambiance for thanksgiving
It is going to be a real somber thanks giving at my mother's in laws house. The plan was to have it there and bring her out from the convalescents home ,but the ambulance arrive before we did she is back in the hospital and this time she will not be returning. There is no good news to report. I hope to see her tomorrow ,if god will allow it. This will be the last time gathering at her house.
geez elk,
im sorry to hear that, my thoughts & prayers are with you guys up there.
Condolences Elk.
Hope you get one more Thanksgiving with her.
Very sorry to hear that, Elk. Best wishes to you and your family.
Sorry to hear the sad news Don. It's hard when it comes during the holidays. Take time to take good care of yourselves too.
