Quad help needed
cudaroy
4
Southern,NH
Hi all,
I am new to this forum but not to pellet stoves.
I recently picked up a used Quadra-fire classic 1000 and have a question. I have cleaned (I mean really cleaned) this unit as it was a mess! It initially would only run for about 10min before quitting so I got ahold of a owners manual and troubleshot the problem......it now works nonstop. Do any of you know if the feed auger runs continually on these units? It is a one speed only stove.I have the feed plate (no rod on this early model) all the way down to it's lowest setting and the flame is great (not too large or small,great heat, etc.
This is my third stove, I also own a 3 speed Castile insert and a Harman P61A (my favorite) . Have any of you ever hooked up an adjustable electronic timer between the control box output to the auger motor to make it cycle on and off.
Are the newer control boxes compatible with the old style ones and finally can this one speed unit be converted to a 3 speed?
Any help would be great.
cudaroy,
Try posting your questions in 'The Pellet Mill and Corn Crib.' You should get some help in there.
