The spring stock is on the way for the Santa Fe. At such a small up front cost, less than 4 bags of pellets, any long run gain is worth it to me.
nuYooper said:The spring stock is on the way for the Santa Fe. At such a small up front cost, less than 4 bags of pellets, any long run gain is worth it to me.
Wi Thundercat said:Now this is getting interesting !! Stay tuned! :bug:
tjnamtiw said:Wi Thundercat said:Now this is getting interesting !! Stay tuned! :bug:
We're waiting for you to get some flat stock to put in those 16 tubes! Join the party!
Countryboymo said:I think even one small piece of thin flat stock in a slow spiral would make a huge difference. I am thinking of what material to use and how or where to get the nice even swooping twist.
Wi Thundercat said:Cousin owns a scrap yard and is quite the machinist too! We have built and tried some crazy s#*t over the years ! Most with great results but some were a bust
tjnamtiw said:slls said:Yes different stove, 3 heat settings, low ,med, hi, fan settings, low, hi. the fan speed is different for the 3 heat settings, each higher for each mode.
I work with my hands a lot, maybe that's why I can take the heat.
So you have a high and low setting for each of the three heat settings? Damn, I wish mine had that! The low fan on low heat is about useless.
Like the comment on the 'take the heat'. Hey, I'm married so I CAN TAKE THE HEAT TOO ha ha ha. I have a feeling with the high fan setting on the lower heat levels you are getting better heat transfer.
j-takeman said:I
Lowering the exhaust temps without playing with combustion air has to be a plus to the stoves overall efficiency.
thz123 said:Last night I cut up some different shaped aluminum to 9", and inserted them except the outside 2. I had flat pieces of different thicknesses and widths. Two pieces were shaped like this [ . Those 2 pieces were smaller than the I.D. This was all scrap material. I tried each piece in different configurations inside the tubes. I feel they restricted air flow. I took them all out. At 9" the flat stuff may be too long causing a restriction all the way in the back of the tube were the air comes up from the fan. I did pull a few further to the front of the tube, but they still felt restricted to me. I did drill holes in the ends of them, thinking that I could shorten them and use a piece of wire so that I can pull them out. I haven't cut them down yet, waiting to see what others try. They were good and hot when removed. I plan to watch this thread to see what the outcome is.
B-Mod said:Not sure If I posted it in here or not.....but I am heating my whole house 1600 sq ft with stove on low heat, convection fan on high, springs (thanks tjnamtiw!) in tubes 2 thru 7 (my stove only has 8 tubes, early model). 71 degrees in the house, 20 degrees outside air temp, and snowing. I am burning straight corn, top airwash sealed off, bottom gasket removed. 9 Years and this stove has burnt nothing but corn. I only tried pellets once or twice when it was warm in the spring to use the room thermometer.............
thz123 said:I am about to order the springs, How did you cut them to 9"?
tjnamtiw said:j-takeman said:I
Yep, that's what I have been assuming. If it isn't going up the stack, it's going into the room.
SmokeyTheBear said:tjnamtiw said:j-takeman said:I
You have to watch out for condensing crap out of the exhaust, where are you measuring the exhaust temps at?
thz123 said:I just ordered 2 sets of springs, they ship out Monday.
tjnamtiw said:SmokeyTheBear said:tjnamtiw said:j-takeman said:I
hi Smokey. I measured the surface temp of the exhaust pipe just above where it is attached to the stove's two part exhaust stack. I used that as a reference point for all my tests and measurements.
SmokeyTheBear said:tjnamtiw said:SmokeyTheBear said:tjnamtiw said:j-takeman said:I
Just thought you should know that as the exhaust gets colder things will condense out in the exhaust that you are likely not going to want to see there.
So just keep an eye on it while playing.
