I am new to the forum but have been lurking in the darkness while shopping looking for a good used unit to start out with. I stumbled onto an 06 Castile that was purchased winter of 07 with Mohogany porcelain, the log kit, horizontal pipe setup and marble tile base for $900.00. I was told it was only used for supplemental heat and it appears that way.
I cleaned it up according to the manual and some tips in here and noticed a rope gasket on the left side corner sealing the ceramic panel at the corner. This is the left side with me staring at the stove. The right side has no rope gasket on that corner of the ceramic panel and the fan is right behind that panel. I would assume that the right one would need the gasket to seal the exhaust and heat from skirting around the panel and right to the blower instead of the left where it appears it is sealing nothing.
The reason for this question is I have ran two types of pellets Rocky Mountain soft wood pellets and ozark hardwood pellets and the previous owner had the slide fully open in the hopper and I rarely had any flame above the fire pot. I called the dealer and wasn't clear if he got confused on which side of the stove I was talking about on the gasket but I think I did get confirmation that only one rope gasket is needed back there... but what side?
I was also instructed to go back to the rocky mountain pellets and set the pellet feed in the hopper to half way and unplug the stove for a minute rotate the knob in the control box one click so I get 5 flashes instead of the factory setting of 4 so I have 10% over factory feed setting. I did see some improvement moving the gasket to the right side or it seemed to make a difference. The 10% over feed made a huge difference and I can now get the flame up where it should be even on the hardwood pellets.
I have a clean out T and 3.5' vertical section of pipe with a 90 and then a 5' horizontal section with a lot of rise. I really need to add another 90 but could get away with one 45 and a 3' section to turn out past the side of the deck. The person from the stove store didn't think it would be a problem to build the pipe on out as long as I kept the rise going on and used two 45's if I did make another 90' turn.
Anyway enough gabbing... anyone know what side of the stove is supposed to have a 3/4" rope gasket. and has anyone had to turn the control module up to the "10% overfeed% setting to get enough burn?
It puts out a bunch more heat on medium and low than it used to now, that I do know. I tried to run it on low before and it would almost go out and I am sure in time it would have went out.
Any help learning would be appreciated greatly.
Thanks,
Bob
Thanks,
Bob
