Quadrafire Castille Door Gasket
rnjsmommy
1
Washington State
We are replacing our tadpole door gasket on our Quad Castille. It did not have gasket across the top of the window/door however we've seen posts that others have it across the top and not across the bottom.....any help?? We don't want to goof it up but it seems like you would need it across the top in order to keep the dust & smoke out of the room.
Thanks!
Is it possible that they gave you the wrong gasket? I have the Castile and my gasket goes from lower left, top left, across to the top to top right, then to the lower right. The bottom is not sealed, nor is there any gasket.
I have seen some from the factory with the glass installed upside down. You should have gasket on the sides and top, open on the bottom.
