    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Ben Altieri New Member
    Just replaced the igniter on my 2005 Quadrafire Santa Fe insert. However even the new igniter doesn't get hot. Pellets drop into cup, fans work fine. Might need a cleaning. But how can I troubleshoot this problem with igniter not heating up.
    Thx- Ben Altieri
    #1
    Helpful Sponsor Ads!
  2. Crane Stoves Member
    Duxbury, MA.
    did you put the ceramic contacts onto to leads when you replaced the igniter (these are sold separately)?
  3. tjnamtiw Minister of Fire
    North Georgia
    ceramic contacts??????
  4. heat seeker Minister of Fire
    Northern CT
    Welcome to the forum, Ben!
    The old ignitor may have taken out a fuse on the control board when it died. If it's not too difficult, you could take the new ignitor back out, and wire it to 120VAC to see if it's good. Be careful, electricity can kill, and the ignitor will get HOT if it's okay.
    I'd suspect a blown fuse or bad wiring first, though.
  5. kinsmanstoves Minister of Fire
    use a meter and check the resistance on the igniter. Next hook the meter up to the two leads from the stove, are you getting any voltage?
    Eric
