Question on the basics
My hottest fires have N/S splits on the top/bottom, and E/W in the middle. That way air makes it to all areas of the firebox.
Yep. Getting air under the fire will do that. But earlier you mentioned burning with full air. That should never be necessary with dry wood. It can make for a cooler stove but a much hotter flue.
Might have exaggerated a bit. To really crank the thing it runs hottest at 3/4. Of course, with this insert I can't measure flue temps or stove top temps, so I'm flying a bit blind. Again, this is regardless of wood. Bricks, 3 year oak, 2 year pine--I promise you it's dry stuff. But full air until everything catches, which can be a long time if it's loaded wrong. This might be more noticeable on a small firebox as well.
It's very hard to load a 602 E/W. ;-)
