Quick question about gasket replacement
jrems
290
Danbury CT
www.epichomebrew.com
Hi guys , I had a quick question. I replaced the door gasket and I was reading about the dollar bill test. The side of the door with the latch is very tight, almost can't pull the dollar out. On The hinge side the dollar slides out easier, still a bit of friction but not as tight as the other side. Should I leave it as is, or should I adjust the the hinge pins?
Thanks-Jeremy
I would adjust if you can.
The dollar will rip if it's tight enough...but try not to do that..lol.
