removing Harman Accentra burn pot
tsmith
843
Kutztown, PA
Does anybody have any info on removing the Accentra burn pot? I want to remove it to do a thorough scraping of the pot and open all the air holes.
Hello
Just undo the 4 bolts but if you do, you need to put in a new white high temp Lytherm gasket when you re-install .
Thanks, And I assume you access these bolt heads from inside the burn chamber
Yes
You also have to undo the coiled igniter wires in the back of the stove so you can pull the wires out far enough to pull the clips apart to disconnect the igniter.
