BB, your so generous.I'll sell ya a couple of fuses for $19 to save you some money. Shipping included.
Yeah we talked about that in this thread:PS: 70 cents worth of fuses for $27? A strain relief for $32 This is beyond the defense dept's budget.
View attachment 127696 View attachment 127697
Having some experience with limited income housing, a pellet stove would not be a good choice for their home. Maybe a gift to the Restore store and they can resell it and use the funds for shelter etc.Wow. At that price I should order a couple sets!
you could oil down the cast iron bricks with vegetable oil the burn them clean in a fire pit or with a torch, i wouldnt replace them you can save them .View attachment 127725 View attachment 127727 View attachment 127728
The white enameled cast iron is in near perfect condition with nary a nick or chip in it. Just the steel and interior cast plates are rusted. Here is a stripped down view from a few minutes ago. I have to get some 3" exhaust pipe to test the stove with after I further clean and paint the hopper and auger. If it can run well and cycle I will attack the firebox itself.
PS: How does one remove the burn pot on this stove. I want to strip the interior for a good cleaning and repaint.
yes it is they are very nice stoves, my friends all have harmann stoves and are always commenting on how much heat and how quiet the enviro is, you can barely hear it runIt looks similar to your avatar. The main issue with this stove is neglect. I think it failed with a corroded and plugged vacuum barb and the owner gave up and put it on the porch where it sat for a year, poorly covered and internally rusting.The hopper had several inches of water that I bailed out when I got it. All systems seem alive, but it needs a lot of love for the inner steel parts. Crying shame really.
Not leak so much as dries up, or sometimes not enough applied at the factory.Does it leak grease?
Most homes will not get above 90 but that stove sat outside probably in the sun and the lube could have settled in the gearbox and wont protect what its supposed to. Ounce of prevention now could save$$$ a some skin.Does it leak grease?
The empress,newer replacement model,was selling for 2900.Being used,over 5,fixed up ok,I'd say 1000.Replace all the steel and electronics,maybe 1900.that sounds just like my stove,I know my stove pretty well so if you need pics or help just ask, thats like a $4500 stove good score
Empresses take their vac sensor from the air intake to the burnpot via a metal hose attached to the vac line. Same WC switch. Just plug up the exhaust barb connection.It is white enameled cast iron jacketed, though it looks like a steel box inside the cast. It's a little hard to give a good picture right now because I have it all apart, but it looks like the Windsor from the manual.
I got the combustion and auger motors working. Tried plugging it in, but found one of the fuses blown. Replaced that and she lit up and tried running for about 30 seconds. Then red light flashing indicating vacuum switch failure. Oh well at least the control board appears ok. I found the silicone tube off the vacuum switch just flopping around in the back of the stove. It has a tiny aluminum barb that is corroded shut. Where does the orange silicone vacuum tube and this barb normally connect to? I can't find any port where it looks like it would belong. The barb is tiny, maybe 3/4" long and ends with an orifice. This is the part - note the price!! And that is the best price I could find!! Crazzy parts prices for this stove.
http://www.stove-parts-unlimited.com/Sherwood-Industries-Aluminum-Hose-Barb-p/ef-019.htm
