Scandia 810
PookaPie
3
Central MN
Hi!
We have a Scandia 810 stove made by Franklin Casting Company, and are wondering what it might be worth, could you let us know? It is about 30", large/square, cast iron, double doors and fits about a 24" log or more.
Also, we have been thinking of trying to have some glass doors made so that we can see the fire, do you have any recommendations on how we can do that? I can provide a photo if you need to take a look at it. If you do not recommend doing this, could you recommend a stove that would be comparable in size? We heat primarily with wood in the winter and need a larger stove, but they are harder to find.
Thank you!
PookaPie said:
Hi!
Thank you!
The old cast iron Franklin stoves are not very popular here. A search on Craig's List might give you a better idea of its market value.
As for your replacement stove - could you give us an idea of what budget you have in mind and the house size or area you will be trying to heat. That will be a big help.
Oh, and Welcome to the forum :)
Probably worth a hundred or two, not worth trying to do glass doors.
I agree the glass door on this rig would not be feasible.
Basically, the stove has scrap metal value. Get a stove with a glass door by design and you will have a much safer, better experience and will use a lot less wood for the same amount of heat.
Thanks for all the info! We have a 1,200 sq ft home with basement, but have been looking for stoves in the 1,800 to 2,500 sq ft range since those are the ones closest to the one we currently have. As for the budget, the stoves that we've looked at range so much in price that it's hard to say what we would be willing to pay just yet. It will depend on the stove too!
Thanks!
Does the 1200 sq ft include the basement? Where would the stove be located, basement or first floor?
The 1,200 sq ft does not include the basement, that is the main floor only. We have a full unfinished basement. The wood stove is on the main floor in the living room. The living room, dining room and kitchen are all one open room, vaulted ceiling. Hope this helps!
Thanks!
I'd look at a mid-sized stove in the 2 cu ft range. These can run in price from $700 to $2500 depending on the style and features. Do you know if you prefer a steel, cast iron or soapstone stove? The location might constrain the choice. Is the franklin freestanding or sitting in a fireplace.
