    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. BlueMavWood New Member
    NYS
    Hi, does anyone know if the information (make, model number, UL rating etc.) stickers located on the sides of Selkirk metal chimney pipe should be removed prior to fireing? The stickers appear to be a metalized material but they do come off easily if desired without leaving residue. Seems like good information to have there for future referance if they don't burn but I don't know if they are designed to stay there or not. Anyone know? Thanks.
    #1
    Helpful Sponsor Ads!
  2. webby3650 Minister of Fire
    southern Indiana
    There is no need to. It likely won't be hot enough to even release the glue. Sometimes the label is on the front of the pipe and is an eyesore so I remove only the ones that show. They often end up on the seam that is on the back anyway.
  3. fossil Super Moderator
    Bend, Oregon
    Stovepipe, or Class A chimney pipe? In either case, if you want to preserve the info for posterity, just take a nice clear close-up pic of the sticker...then either remove & discard it (interior stuff, maybe), or let nature take her course (exterior stuff, maybe).
  4. EatenByLimestone Minister of Fire
    I rotated my pipe so the stickers were facing the peak. Unless you are on the roof you can't see them. It's funny what we pick up on. I was more worried about the black line of mastic showing too much.
    Matt
  5. BobUrban Minister of Fire
    Central Michigan
    Mine are surviving their second season with no sign of deterioration on both Class A snd DBL wall stove pipe. Just rolled them to the back on the stove pipe.
