Good Afternoon!
I am new to this forum and already it has provided a wealth of information. Much of what I "know" about stoves comes from here...so thank you already!
My current setup is as follows. I have an Avalon Misson Steel stove (http://www.avalonfirestyles.com/travisdocs/93508114.pdf) in a 350 sq ft finished basement. The stove can takes 16" wood most comfortably (but will take 18" if necessary as the firebox is about 20" wide...it's 1.8 cu ft). Above the stove is 1400 sq ft of living space, most of it (~1000 sq ft) on the main living level (which has vaulted ceilings) and then one bedroom on the second floor. There is an open stairwell to help heat move upward as well a a register cut through the floor right above the stove (with a small muffin fan to help draw heat up).
While I love burning wood and have no plans to change, the current configuation leaves a few things lacking:
1. We live near Gaylord, MI...where winters are pretty chilly. On a cloudy 15F day, the stove has trouble keeping the main living level about 65F. We have only lived here two years...but I'm pretty sure the stove was originally used as supplemental heat...rather than the only source...as we have done.
2. I would really like to cut my wood to 18" (with an occasional longer piece). Easier on the saws...and my back
3. Throughout the core of winter, I am up at least once (sometimes twice) during the overnight to completely restoke the fire...just to have enough coals at daybreak to get things going again.
So, I have been researching larger stoves, with lots of help from this forum, as I mentioned above. My personal preference is to go for Cast Iron (non-catalytic), solve some of the problems above, and have a stove that's going to last me a good long time. From what I have read so far, The Quadrafire Isle Royale has come to the top of my list. The company looks good, the stove is beautiful, and I have what looks to be a good dealer very close. However, I have some questions about this:
1. Is this too much stove? We use the finished basement and I don't want to run us out of there. The heat does seem to flow upwards well... but It's a much bigger firebox. I looked into the Cumberland Gap...and while it is slightly larger, it seems like I'm going to run into the same problems (log size and heat amount).
2. Can this stove last the overnight?
3. Are there other stoves I should really consider? I have looked into the Jotul F 500 Oslo, VC Defiant and the Hearthstone Heritage. Given my proximity to the Quadrafire dealer and the good things I have heard/read about the company...I would still lean towards it...but am open to any thoughts.
4. Anything else I should be thinking about? I'm still a novice...so could be missing a lot!
I thank you in advance for your assistance!
Justin
Highs in the mid 60s today...winter can't be that far away!
Justin
