Slab sensor thermostat
emesine
185
Indiana
I need a few thermostats that will sense the temperature of a cement slab. I am going to connect them to a TACO SR506 control unit. Does anyone know a brand they would recommend?
Andrew
I am useing a tekmar 150 thermostat , not sure how it is all wired up tho.
all i know is the taco sr series use a 24 volt thermostat
but you may take a look at the RANCO, drill a hole in the slab and bury the sensor with caulking, so you can remove it if you want
http://www.rancoetc.com/
You might consider a thermostat that watches air and slab. It's real hard to control a radiant zone with just slab sensing. Unless it is a snowmelt.
I like the tekmar 500 series. Watts Radiant and most of the other radiant companies offer dual stats. Install the sensor in a well, like a piece of 3/8" copper tube, as they do fail from time to time.
hr
Tekmar 510 looks pretty slick. I got a better response from you guys, and it took half the time.
Andrew
hr
yes that is better than the RANCO
