    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. joshuaviktor New Member
    Northwest New Jersey
    I am eventually going to put a stove in my bedroom fireplace. Original plan was to put a propane set in, as we already have propane to the two ranges in the house. However, I am not sure how easy it would be to route pipe up to the fireplace without doing some demolition. As well, I undeerstand its not cheap to run one of those suckers ($1 an hour).
    Anybody know a real small pellet stove, or maybe a hand fired coal? Fireplace is full size, with full mantel, and everything, and my bedroom is the old dancing room for the inn, so its not small. But I don't need a huge stove to roast us out. I'm going corn and wood for the house, but would have no objections to a small bit of a third fuel supply (pellts or coal). Just a pipe dream right now, making plans for the future.
    My bed is right near the fireplace, so I don't want a screamingly loud pellet blower, but pellets/corn are the cleanest fuel to carry into the house, and I could keep standardized fuel supplies (sorta). Also, I like the ability to thermostatically control it, and even turn it off, without having to wait 12 hours till the coal burns out. But coal is a great fuel, and burns with a deep warmth. Ah well, it'll be two-three years before I can even think about it, as expensive as those suckers are.
    Any ideas?
    #1
    Helpful Sponsor Ads!
  2. MountainStoveGuy New Member
    maybe the quadrafire castile insert? running on low there fairly quite and work on a stat incase you dont sleep naked.
    Ryan
  3. joshuaviktor New Member
    Wait, there are people who don't sleep naked??? Weirdos!
  4. Czech Minister of Fire
    Twin Cities, MN
    I agree with the Castile idea, not aware of anything smaller. They say they put out 30,000 btu full bore, but with the stat and 3 speeds you can adjust accordingly. We run a freestanding one, learned that it's better to keep on Med and set the stat rather than running on low all the time. Burns cleaner. I've noticed that the supplied stat with the unit isn't that sensitive (at least in our case, the stat is about 5 feet from the stove on an adjacent wall), it needs a 3-5 degree change before doing it's thing. Good luck,
    B
  5. joshuaviktor New Member
    Looked at the castile. It's attractive, 7000 btu/s an hour is fine to more than enough, and I understand Quadrafire is a pretty good brand. In the quadrafire website, it says fuel Wood Pellets/Shelled corn. It'll burn either, mixed, or separate? 100% corn, 100% pellets, mixes of both? Anyone? If corn, I have standardized fuel for the house. If Mix, don't mind buying a few bags now and again. And howmuch is a castile, street price?
    Thanks for the info
    Joshua
  6. MountainStoveGuy New Member
    classis black MSRP 2079
    basic surround MSRP 69.60
    Enamle brown 2379
    Panel 53.40
    trim 145.20
    These are MSRP. Make shure you buy local, no matter what the cost is. Some people charge freight on top of that. This is the least expensive way to equip the castile, you can add cast trim to the surround, and get severl color options.
  7. Czech Minister of Fire
    Twin Cities, MN
    Josh,
    Either/or. I burn a 50/50 mix in mine, but I have burned 100% corn too. Stove will not reliably auto ignite at higher corn mixtures and not at all at 100% corn. I clean it once a day burning the 50/50, no significant clinker problems, everything falls in the ash tray with very little scraping. Seems to be a good stove so far (only running a little over a month 24/7), except for my roaring upon startup problem posted previously (see Pellet Roar). Prive was right around $2K for the stove alone, came to around $3K for everything including vent, hearth pad, etc. Installed myself, no problem. Cheers, it's Friday,
    B
  8. Xena Minister of Fire
    South Shore MA
    Check out the Thelin Little Gnome (pellet stove). Small footprint, unique looks.
    I've heard good things about them. Don't know pricing but check
    the site for dealers and give a couple a call. There's the link to the stove:
    http://www.thelinco.com/stoves.htm
  9. MountainStoveGuy New Member
    I think a thelin is a good suggestion, if you dont live in altitude, they split the duties of the combustion and convection blower with one blower, and does bot provide enough back pressure on the pressure switch. But they do look great, and work great, i have the least amount of service calls on thelin then any other pellet stove. That could just be do that it represents less then 2% of the stoves that i have out. They just dont work well at 6500-7000' and above.
  10. Corie New Member
    Halifax, VA
    There was another/is another company that makes a very small pellet stove meant for one room. It had a push-pull rod for air control and a firepot the size of a styrofoam cup. I just can't remember the name......
  11. hearthtools Super Moderator
    My experience is MOST pellet stoves are not approved for Bedrooms
    and EVERY one that I have installed in a sleeping area people hatted it because of the Noise and they put out to much heat.
    Pellet stoves sould not go into a room smaller than 600 sq feet because that is what they will heat at there lowest settings at 1# an hour
    Automatic stoves that shut on and off will light and shut off way to much.
    Gas is your better choice. Easyer to control the heat and no mess no noise/
    you can run a Small gas stove for about 4 hours on a gallon of LP.
  12. wg_bent Minister of Fire
    Poughkeepsie, NY
    Morso 1410 coal stove, Harmon mark I (twice the size of the Morso), and a Esse 500. All coal.
  13. Corie New Member
    Halifax, VA
    hey hearthtools, are gas appliances usually approved for bedroom installation? (I know that pellet stoves usually aren't)
    Just wonderin
  14. Shane Minister of Fire
    Casper Wyoming
    Alot of DV fireplaces are.
  15. hearthtools Super Moderator
    MOST direct vent unit are approved for a sleeping area for they DO NOT use room air for combustion.
    The old code for Gravity or B vent unit is you can if the sleeping room is not unusualy tight
    and can not have more than 1000 btu for every sq feet of area. or is it qubic feet
    something like that ??
    I dont have the excact wording around for I would never put a B vent unit in a sleeping room and I have not sold a B vent gas unit in years.
  16. Corie New Member
    Halifax, VA
    ahh gotcha. I have to tell you I never really looking into gas stoves at all, but now I know!
  17. babalu87 New Member
    middleborough, ma.
    If the rest of the house will be wood, why not go with a Jotul 602?
    You may find one in the off-season for a decent price
    They light FAST and would be perfect for a big room
    Just a thought
  18. wg_bent Minister of Fire
    Poughkeepsie, NY
    Yes, the 602 is another great suggestion. I can't believe I forgot that one. Lopi makes a nice little radiant stove, as well as the really beautiful Vermont Castings Aspen. Won't vouch for quality of the Aspen, but it sure looks nice, especially the enamel ones.
Thread Status:
