I am on the learning curve for my Englander 30-NCH and am wrestling with enough fire/secondaries to get no smoke out the chimney. Sometimes when I have secondaries, there is zero smoke, other times there is a small bit coming out the chimney. The smoke is white vs blue/grey and generally you can see through it. This makes me wonder if what I am seeing is smoke or steam.
This stove, being a secondary burn type stove is much different than my other cat stove. Then I engage the cat and it fires off - there is zero smoke or steam. It is though you are not burning anything in that stove when looking at the chimney.
So out of the same pile of wood, with the cat, I get zero smoke. With the Englander, sometimes no smoke, other times a light smoke (or steam) with the secondaries going.
My question for you folks with secondary type burn stoves is:
1. Do you think I am seeing smoke or steam?
2. How much steam/smoke is normal for your stove to discharge with the secondaries going? Is your stack always clear or is there some smoke/steam coming out?
Just courious.
Thanks!
Bill
Just courious.
Thanks!
Bill
