Smokey Fire - Need Help!
bob95065 Posted By bob95065, Oct 7, 2013 at 11:17 AM
Thread Status:
  1. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    We bought a home this past August that had a Sierra side-loading wood stove in it. I also installed an Avalon Rainier at the other end of the house. I am used to EPA stoves like the Avalon I installed at the other end of the house. It is the same stove we had in the last house. I tried starting a fire in the Sierra Friday morning and had a hard time. I do have a lot of experience with wood heat. I heated the last house with wood for 10 years and never had a problem.
    I was burning some oak that I cut and split the summer of 2011 so I know it is dry. I got the fire lit and closed the door. As soon as I closed the door there was a lot of grey smoke coming out of the flue. I made sure to fully open the air dampeners on the door so the fire could breathe. The stove has two air inlets that you turn by hand on the door.
    I had to open to door to get the fire to stop smoldering and the smoke to go down. It was so bad a neighbor came over from across the canyon because she thought our house was on fire. Anyway, the room began to fill with smoke so I closed the door again and lived with smoke until the fire went out.
    What I am I doing wrong?
    I am going to inspect and sweep the flue this weekend. I wonder if there is creosote restricting the flue which would cause the fire to not draw air properly. Other than that I am at a loss as to what could cause the smoke and poor performance of the stove. I'll post pictures of the stove when I get home.
    TIA,
    Bob Elliott
  2. USMC80
    USMC80
    Minister of Fire 2.
    NULL
    Mar 27, 2013
    842
    389
    Loc:
    New Jersey
    Def check the flue and cap for some kind of blockage
  3. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    I checked it when we bought the house. The cap and spark arrester are clear.
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    South Puget Sound, WA
    Sounds like poor draft or the wood is not as good as expected. Check the flue for obstruction like a hornets nest.
    Describe the entire flue system from the stove top to the chimney cap? How tall is the flue? Pictures may be helpful here too.
    Just to eliminate the wood as a possible cause, try burning some construction scraps and see if they burn the same or much better.
    Ashful likes this.
  5. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    I thought about burning some bone-dry redwood frm stump I cutup on the property. It was dead whe I cut it so I kow if is dry.
    We bought the house the endof July so I don'tknow what theflue is made of. It i enclosed in a brick chimney. The stove is an insert.
    I plan on gettig up there tomorrow. I am taking a day off to work on the roof.
  6. Ram 1500 with an axe...
    Minister of Fire 2.
    NULL
    Mar 26, 2013
    2,327
    670
    Loc:
    New Jersey
    You said you completely opened the flue after the smoke already started, how open was it if at all before you started? what was the temperature outside during the day that you started this fire? Could be a nest like BG said, I'm thinking no draft going on at all as opposed to poor draft...
  7. gzecc
    gzecc
    Minister of Fire 2.
    NULL
    Sep 24, 2008
    4,458
    870
    Loc:
    NNJ
    Roll up some newspapers and shove them up the flue. If they don't create a draft. There's your problem.
  8. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    We moved into this house the middle of August after spending two weeks fixing the stuff the DPO (Dumb or Dreaded Previous Owner) did to it. This house was worked over pretty bad.
    I spent four weekends running fixing the concrete tile roof. I am taking tomorrow off to finish it up. When I went up there the first time there was a plastic garbage bag and a rope tied around the cap on the chimney. I don't think the DPO had enough know-how to remove the cap and stuff something down there but I could be wrong. Then again maybe there were stinging insects nesting in there and they trapped them inside to starve.
    I didn't say I opened the flue. I opened the door to reduce the smoke. The fire did burn better but we got some smoke in the room.
    I am going to go on the chimney with a flashlight and inspection mirror to see what is down the flue. I'll also bring my brushes to sweep it clean after I look down there. Oncew it is all clear I'l burn some construction scrpas as suggested.
    Thanks for the help.
    Ashful likes this.
  9. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    Good plan, keep us posted.
  10. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    I pulled the cap and the flue is clear. There is no metal pipe. The chimney is stone with an oval stone pipe. I haven't seen anything like it.
    I plan on using a mirror and flashlight to look in the stove side next.
  11. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    I know what is wrong with the stove.
    I decided to pull it out away from the stone wall. They set up the insert and surround into an existing fireplace with no flue liner. What is worse is they isn't fully open the damper which us why the fire wouldn't draw. They must have burned pine because creosote has built up on the lever so thick I can't move it.
    I am going to get a flue liner kit and do this right. I think I may need to cut the steel baffle out of the fireplace in order to make this work.
    Does anyone have a suggestion on where I should get a flue liner kit at a low price?
  12. Ram 1500 with an axe...
    Minister of Fire 2.
    NULL
    Mar 26, 2013
    2,327
    670
    Loc:
    New Jersey
    Be green probably knows..... Doing it right is the way to go....
  13. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    First order of business to to have the chimney completely clean, including the smokeshelf up behind the damper. Then no burning until the liner goes in. There are lots of places to order liner kits including eBay. If you want predictable quality and service a couple of the majors are Rockford and ChimneyLiner Depot. Northline Express also sells liner kits.
  14. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    Do you suggest cutting out the smoke shelf and baffle when I put the liner in?
    No more burning here. The closed damper caused smoke in the house. I have an Avalon Rainier in the room in the front of the house that we are using.
  15. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    Before starting, what is the length and width of the oval flue currently there? Will a 6" round liner pass through to the fireplace unobstructed?
    If there is 6" clear when the damper is open then leave it in. In some cases the damper can be removed without cutting. See if there is access to the pivot rods and if they are bolted in or welded. If no access then yes, a notch may need to be cut in the center of the damper to increase the clearance for the liner. There shouldn't be a need to cut the smokeshelf.
  16. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    There is a 8" x 13" terra cotta liner in the stone chimney. A 6" liner will pass no problem.
    I didn't get a good look at the dampner pivots. I was pretty disgusted when I saw what they did. If I get home somewhat early tonight I'll pull the stove out and snap some pictures to post.
    I was thinking about this problem over the weekend. I wonder if I can break the creosote loose with a hammer and cold chisel. I won't know if a liner pipe will pass through the damper until I am able to open it fully.
    When we bought the house there was a black garbage bag around the cap on top of the chimney. They used a bungee cord and rope to hold it on. My guess is they wanted to stop cold air from blowing around the surround through the open flue so they tried to seal off the chimney. Maybe if they put some thought into this and did it right with a cap and liner this problem would have been solved and the stove woudl be functional.
  17. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    Yes, it is a dirty job. Wear a dustmask.
    If this is an exterior chimney put in an insulated liner, especially if the chimney is one story.
  18. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    This is an exterior stone chimney that is one story. The room has a vaulted ceiling and the wall is all stone where the chimney is. What is the insulation for?
    I have an opportunity to get some black 6" rigid pipe for free. Can I put it in the chimney? I figure there is a reason for stainless flex pipe but I thought I woudl ask. It's worth a try if I can get it for free.
    I wish i new about this before we put new carpet in the house this past August. I may get some rosen paper for the floor too. I'll probably have to take the stove competey out to do this job.
  19. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,883
    8,630
    Loc:
    Black pipe can not be used in the chimney for a liner. It has to be stainless. The purpose of insulating the liner is to keep the flue gases hotter. This will improve draft and will help reduce creosote deposits.
  20. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
    I figured you would say that but I thought it was worth a try. I'll look for an insulated flue liner kit.
  21. bob95065
    bob95065
    Burning Hunk 2.
    NULL
    Aug 13, 2013
    161
    82
    Loc:
    Felton, CA
Thread Status:
