I suppose I should tell of my setup first. I run a 30 to an external 25+ft block chimney that is lined with a terra cotta liner. I shoved a 5.5" insulated liner from Chimney Liner Depot down it and then stuffed some loose Kaowool blanket around the top to try to keep as much heat in as possible. I figured it might decrease the creosote a bit.
So back to the effectiveness:
The stove and chimney were cold since I've been working long hours and didn't have time to load and tend it. We also got about a foot of wet snow yesterday, so when I woke up this morning and looked at the chimney it looked odd with all the snow on top. I fired up the 30 to melt it off. The snow melted off the stainless that peaked up above the chimney and wetted down the outside of the block. I just went back out to gather wood (around 11pm) and noticed the chimney was still wet very wet. The chimney is cool enough where the water did not have any help evaporating off.
What can we gather from this? Well, I can't infer that gasses are moving faster or that less creosote is building up, but I can say that the heat that does leave the stove is not transferring to the block. For not that much insulation wrapped in a reflective liner, it's pretty effective.
Matt
Matt
