splitter design help
boostnut Posted By boostnut, Nov 18, 2007 at 2:02 PM
Thread Status:
  1. boostnut
    boostnut
    Member 2.
    NULL
    Nov 2, 2007
    219
    0
    Loc:
    central IL
    I'm in the middle of a major rebuild on an old John Deere splitter. The whole thing is disassembled and will be nothing like the original when I'm done. My questions are as follows:
    1. Does your splitter have a filter for the hydraulic fluid? If so, is it in the return line between the tank and valve OR in the intake line between the tank and pump?
    2. What fluid should I use for mostly cold weather (< 50 degrees) work? I dont have an operators manual or any info on the cylinder so I was just planning to use a typical tractor hydraulic fluid, not sure of what weight to use though.
    3. Does your hydraulic tank have a breather or just a pipe plug in the top fill port?
    Any input appreciated, Aaron
  2. Corey
    Corey
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    2,306
    162
    Loc:
    Midwest
    1) Generally there is a strainer on the intake inside the tank (screen mesh ~100 microns) then the spin on filter is on the low pressure return line to the tank (~10 microns)
    2) The pump is the most critical component, and what would govern the viscosity/type of fluid to use. Then you would look at the minimum expected start-up temp, and max expected operating temp (called the 'operating window') and find something that brackets that viscosity. But, barring any manufacturer specs or recommendations, I'd just go with some middle of the road / all purpose fluid. This link has some info, but again, you need the mfr's recommended specs.
    http://www.machinerylubrication.com/article_detail.asp?articleid=974
    3) The tank should have a breather as a minimum - a breather/filter/desiccator would be ideal, there will be a fluid volume change when everything heats up or cools down, plus when cycling the cylinder from the rod side to the back side of the piston, the rod displaces fluid, so it's gotta breath.
  3. Rich M
    Rich M
    New Member 2.
    NULL
    Aug 22, 2006
    159
    0
    Loc:
    NW Lower Michigan
    1) Intake between the tank and pump.
    2) ATF below 30F.
    3) Breather
Thread Status:
