Marty S said:Battenkiller said:Marty S said:Radiant vs convection?
Physics tells us a warm surface at a lower temperature (165* F) emits RADIANT energy of LOWER AMPLITUDE than that of a hot surface (450* F). The effect of this, with time, is the lower surface temperature material warms objects and not the air (like rays from the sun on a cool spring day). The hotter the surface temperature, the higher the amplitude of the radiant energy which then strikes more molecules of air causing more CONVECTION heat (more indoor weather). The truth is most all stoves emit both radiant heat energy and cause convection heat as well.
Actually, just the opposite is true. Above 200ºF, the higher the temperature, the more heat is emitted as IR and the less natural convection occurs.
Amplitude in EM is a measure of the intensity of the field, not the wave "height". EM waves are not the same as matter waves (i.e. water, sound), and have no physical measurement (except in wavelength and frequency). Convection occurs because air molecules come into contact with the hot surface and become hotter through conduction from the hot material itself, not because radiant heat strikes the air molecules. In fact, air is fairly transparent to IR radiation, and so is a poor absorber of heat from that source.
For most radiant stoves operating at temps from 400º to 600º, about 30-35% of the heat is transferred via natural convection. At the lower temp range of masonry heaters (about 100ºF), 35% of heat transfer occurs happens through convection. These are not theoretical figures, they are experimentally derived measurements.
Please, don't take my word for it.
On Photon Wave Amplitude, and other:
"Because the particles in solids and liquids are relatively closely packed together they are very good at absorbing any radiant heat photons that happen to strike them. On the other hand gases, such as the air we breath, have enormous amounts of empty space between particles. As a result, the chance of photons hitting a gas particle is much smaller. The distance that a photon can travel through gas before striking a molecule is dependent on the amplitude of its wave motion. This amplitude will be greater (higher) in radiation from a hot object than in a cooler object. The greater the amplitude, the longer the path a photon "particle" will follow in order to cover a given distance through the gas and the greater the probability of encountering a gas molecule along that path.
Convective heat is an indirect form of heat transfer. The heat is not transferred directly, but rather indirectly through the medium of the air in the room which acts as the means of transport. The continual movement of air in a room heated by convection from a hot metal stove or a forced air system results in uncomfortable drafty conditions and uneven temperature zones. By contrast, in a room heated with a radiant heat the air remains still, eliminating uncomfortable drafts, with air temperature staying comfortably even. (my style change)"
Aye,
Marty
Say what they may, our convective stove heats our 2000 sq ft house very evenly. The quoted statement does not make it fact. Most forced air systems that are uncomfortably drafty are poorly installed HVAC systems. When I was doing this type work it was a common complaint, most often with adapted gravity ducted coal system that had the supplies and returns in the wrong locations. A well installed system should not feel drafty. FWIW, the radiant masonry heater convects a lot of heat too. It warms the air in the core of the house that travels in a loop across the ceiling and then cools and descends down the cooler outer walls of the house. That was the point of the article supplied:
"While anyone who has stood close to a house radiator in operation can attest to the direct and potent heat it gives off, steam heat also works in a secondary but important way. As hot air from the radiator rises, it displaces cold air above, which sinks and is warmed by radiator. This process of circulation is called convection.
