I know that many say it isn't necessary to seal stove pipe joints. However, my setup has a rather large gap where the pipe meets the stove which I fill with loose rope gasket material in a couple of spots, but that doesn't really prevent air flow to any significant extent. I am no expert, which is probably why I can't understand how an air leak is not a problem. Modern stoves seal the doors and seams well, yet (I believe) the draft in the chimney caused by rising hot gases and outside air (wind) passing over the chimney will draw air from the path of least resistance (often, "the gap", when the stove door is closed and air flow setting turned down on the stove). That room air is much cooler than exhaust gases which (one again, I believe) will cool the flue gases and create less draw of gasses from the stove and more creosote from cooler flue gasses. My non-expert intuition tells me that, like sucking on a straw in a thick shake, you don't want a hole in the straw where it will pull in air instead.
Please explain how I am mistaken.
I know I can seal the joint with stove cement or the like, but I still want to know how this works.
Thanks
Art
Thanks
Art
