Interesting replies. I've fired my new stove twice so far, and still in the break in period have kept it below 500 degrees as suggested by the Vermont Castings manual for the Encore. Maybe two more burns like this, then I will start to see what kind of real heat I can get out of this stove. One problem is my wood is not as seasoned as advertised by the guy who sold it to me. And when the magnetic stove top thermometer read 500, the stove was not really heating the house, just the direct vicinity of the stove was warm. I was thinking maybe the stove top reading was hotter than actual stove temp because of placement. Woodstoves are space heaters . . . and time dependent . . . if I started my woodstove up from a cold start and just let it die out I honestly wouldn't really warm the place up much . . . they really need some time to heat up the metal . . . and the surrounding environment.
Are the flue gases hotter or cooler than the stove top right above the flames? Or similar? Again, depends . . . I think it's safe to say that the temp in the firebox is almost always hotter than the temp in the stack . . . but the temp of the stove itself may or may not be as hot as the temp of the gases in the flue . . . there is a lot of mass and heat is being "pulled" from the metal . . . and it depends on where in the stage of burning you are talking . . . at start up my flue temp always rises faster and higher than the stove top temp . . . but once I have a secondary burn going the temp of the stove top is generally higher or at least equal to the temp in the stack.
I"m also considering removing the double wall connectors and replacing them with single wall. I have about 30" vertical to a 90 and 6" horizontal to the wall thimble. Am I not loosing some valuable heat exchange to the room with the double wall pipe being so cool. If I downgrade to single wall, that span of connector will increase my heat source to the house, no? Yes . . . but if you have a modern EPA stove the majority of the heat will be coming from the stove . . . this is where the bulk of the heat is generated . . . going to single wall can be done, but you're giving up some perks including the closer clearances.
I had no choice but to go out the wall and go up class A the gable end, but I'm hoping that is not going to make the stove futile at heating the 1600sf of living space. For the investment of the whole deal, I'll be screwed if I cant turn the oil off when this stove is running. If you sized the stove correctly you shouldn't have an issue due to the chimney or stove pipe . . . both Backwoods and I have Class A chimneys that go out and up . . . I cannot remember if Dennis' set up utilizes single wall or double wall . . . in my own case I have double wall . . . and heat a 1,800 square foot home . . . mostly with wood.
any thoughts appreciated
