Super glue fingers
mass_burner
2,645
SE Mass
Is there any trick to applying super glue and not having your fingers stick to the work piece? Some type of gloves?
i thought the only use for superglue was to seal up cuts on your fingers. there are other uses?
Reactions: vinny11950
That is the best use of Superglue, IMO! Much better than bandages!
For small work, I use toothpicks.
get the super glue with the brush it's a lot cleaner. if you use tweezers coat the tweezers with oil it will give enough time to hold and not glue to them
Thanks, I'll look for the brunsh type.
