Table top & saw vise.
bogydave
8,426
So Cent ALASKA
Hard to file a chain with out a vise.
Made a saw vise & mounted it to a piece of plywood for a table top just for working on the chains saws.
Now I can clamp it on the little roll around table & keep the roll around table top clean.
Table top:
Vise: 3 layers of 3/4" plywood, 1/2 all thread, 1/2 NC nut, 1-1/2" square aluminum for the moveable jaw.
/Drilled a 1-1/4" hole in the plywood then cut down to the hole ("off centered" for the stationary jaw) & for chain clearance.
Drilled & tapped the end of the all thread & counter sink screw to hold on the aluminum jaw. Nail for the turning handle.
Table top & saw in vise:
Reactions: ScotO
Don't think I've ever used a vise when sharpening. Throw the saw on the tailgate and hold the bar with one hand and file with the other.
I never did either. But after reading some of the guys post who mentioned clamping the bar in a vise for sharpening, I tried it.
Pretty easy & faster with a vise. Live & learn ;)
Now I have a portable one in the shop, which is where I do most of the sharpening.
May make one for the ATV rack, speeds up the sharpening & I think I do a better job filing with it held in place securely . :)
In the field, I do the same. At home, when I'm sharpening several chains, I prefer the vise. More accurate, less mess.
Worked pretty nice.
Allot quicker & easier to sharpen a chain.
Down side so far, I have filings going into the the threads of the all thread & nut
& need to round (or 45°) the outboard corner of the vise, knuckles hit the corners of the vise filing the small saw.
Reactions: ScotO
I have a 6" vise bolted to an oak 2"x10" about 2' long with a double layer of ice/water shield tacked to the bottom to keep it from sliding around. Great for sharpening on the tailgate of the job truck and fixing other stuff on site.
Reactions: ScotO
A real good idea.
Sure helps to have that extra hand when out in the field.
Do you use anything on the jaws to protect the bar? That's why I thought of wood & aluminum.
I guess the bar gets thrown away when worn out . Nothing for the vise to damage .
Very cool Dave ! I clamp mine into the batch vise with the power head on so I can lock the chain and take my time it works great !
Pete
