bt01344
I have a Thermo Control stove that I am looking into the possibilities of converting over to heat the water in my oil boiler so as to hopefully eliminate the running of my oil furnace in the winter time at least. I have a buderas boiler with an indirect-fired hotwater heater so if I can keep the hotwater in the boiler up to temperature I should be able to be able to heat the baseboard heat and the DHW. This sounds like the same system that JerriEric was using I believe. My question is for him- you said you had a pump that ran the water between the boiler and the wood stove coils all the time. Did you ever have any issues with this like over heating the boiler water?, or not being able to circuilate the water when the power was out? Did you have a differential controller that controlled the circulator pump or did it really just run all the time? My hot water storage tank is in the basement and the stove is on the first floor- I know these systems work better if you have them with the storage tank higher- how was yours? Any info would be very helpfull and appreciated.
Thank you
Brandon
Western Mass
Thank you
Brandon
Western Mass
