OK Thermostats on stoves are a nice feature...I have one that came with the unit but so far just use manual as it just seems to work fine. When we need the heat we turn it on when we don't the stove stays off.
Do they put more wear and tear on the stove constantly shutting down and turning on?
Do you think it uses more or less fuel using one?
Example last one out if its on shuts the stove off manually. The house therm is set to at 55 oil just Incase it will drop that low but rarely if ever happens. so pipes won't freeze.
Many times during the day the house may be 65-66 degrees and is comfortable most of the time unless its really cold and your home then we turn the stove on. There were a few days that we just left the stove on during the day for a few hours while out on a lower setting.
Point I'm trying to make is I don't need to keep the house at 70 degrees when none is home for 6-10 hours so why run the stove.
At this point so far I really see no reason to use the thermostat so I haven't bothered hooking it up. Installing it is simple for me just see no reason for it YET.
CONVINCE ME THAT ITS THE BEST INSTALL TO US A THERMOSTAT WITH MY NEW STOVE.....
