Thoughts to improve tight installation
Seastrike
43
Central Massachusetts
Hello all - I'm hoping to get some ideas from those more competent than I, so Im able to remedy the issue described below. Thoughts and personal experiences greatly appreciated !
With the front of the stove/ insert aligned flush with the stonework, approx 3" of the stoves 6" flue collar aligns under the lintel with a tight 3.00" gap in between.
To remedy this, I recessed the stove into the fireplace opening back by approx. 3", thereby providing the flue collar clearance from the lintel, but also losing the flush fit to the stonework and thus not allowing me to use the surround panels of the insert.
So, Im looking for a solution with the goal of being able to fix this install and be able to use the surround panel with the insert. How to clear the lintel ? Is there enough room to install and possibly use an offset box or other means ?
Thoughts ?
THANKS !!
I think you could find an offset box that would be in the 3" tall range. It sounds like you must have a double lintel, that sure makes it hard sometimes. Your local hearth shop should have some adapters and elbows for you to look at to get an idea. Maybe an adapter like Lopi has would work, it moves the flue collar back a couple inches, then maybe a 45' would sneak in there?
